Zero divsion error
Brand new to ODM and try to run some small tests with foto’s from my Samsung S9.
The first test foto output was okay.
The second one returned the following response:
[INFO] Initializing ODM - Tue Nov 17 13:45:34 2020
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: True
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] max_concurrency: 2
[INFO] merge: all
[INFO] mesh_octree_depth: 10
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: 19c259e3-23ba-4450-9cfb-12454247e96f
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: [‘dataset’, ‘split’, ‘merge’, ‘opensfm’, ‘openmvs’, ‘odm_filterpoints’, ‘odm_meshing’, ‘mvs_texturing’, ‘odm_georeferencing’, ‘odm_dem’, ‘odm_orthophoto’, ‘odm_report’]
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_multitracks: False
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/19c259e3-23ba-4450-9cfb-12454247e96f/images
[INFO] Loading 11 images
app.execute()
File “/code/stages/odm_app.py”, line 86, in execute
File “/code/opendm/types.py”, line 342, in run
File “/code/stages/dataset.py”, line 109, in process
p = types.ODM_Photo(f)
File “/code/opendm/photo.py”, line 70, in init
self.parse_exif_values(path_file)
File “/code/opendm/photo.py”, line 114, in parse_exif_values
self.altitude = self.float_value(tags[‘GPS GPSAltitude’])
File “/code/opendm/photo.py”, line 323, in float_value
v = self.float_values(tag)
File “/code/opendm/photo.py”, line 318, in float_values
return [float(v.num) / float(v.den) for v in tag.values]
ZeroDivisionError: float division by zero
Any suggestions?
Thanks in advance
Should be fixed with https://github.com/OpenDroneMap/ODM/pull/1207 :pray:
Thanks for the report!
