Since install of 2.8.8 I have the current message when opening the ODM Console :
version: 2.8.8
RuntimeError: module compiled against API version 0xf but this version of numpy is 0xe
ImportError: numpy.core.multiarray failed to import
The above exception was the direct cause of the following exception:
SystemError: <built-in function __import__> returned a result with an error set
usage: run [options] <dataset name>
But I have run several task and all I have tried so far seems to work without any issue.
I have no time to check the code but could open a bug on GitHub if needed.
