Will the WebODM Windows 10 Native Integration work if I update to Windows 11?
I am currently running the Windows Native version of WebODM. Will it still work if I update to Windows 11???
I expect it will:
Update: I downloaded Windows 11 and it seems to be working fine :slight_smile:
Hello on my new machine with Windows 11 professionnal, following the ODM installation process, I have just installed Python, GIT, Docker for windows, and I have open Git Gui… Then Open Repository/gitbash and type “$ ./webodm.sh start&”
Then the process stopped at this stage
1638971177808
What to do please ?
Many thanks
Patrick
When I tape “Enter” then it appears
1638971751440
Can you reach outside of your MingW environment with ping? It should have connected to docker hub.
Could you explain ?
I don’t undrestand : outside my MingWenvironment " ??
What is ping ?
Sorry
Patrick
Do you mean : I can close the windows Mingw64
And i could try to open docker ? ?
Patrick
Or, Do you recommand to open a browser and go to “http://localhost:8000” ?
try issuging this from your MingW64 prompt:
ping bing.com
It should respond with something similar to this:
PING bing.com (2620:1ec:c11::200): 56 data bytes
64 bytes from 2620:1ec:c11::200: seq=0 ttl=54 time=204.589 ms
64 bytes from 2620:1ec:c11::200: seq=1 ttl=54 time=229.355 ms
64 bytes from 2620:1ec:c11::200: seq=2 ttl=54 time=226.850 ms
64 bytes from 2620:1ec:c11::200: seq=3 ttl=54 time=276.806 ms
64 bytes from 2620:1ec:c11::200: seq=4 ttl=54 time=301.928 ms
64 bytes from 2620:1ec:c11::200: seq=5 ttl=54 time=325.374 ms
64 bytes from 2620:1ec:c11::200: seq=6 ttl=54 time=144.666 ms
64 bytes from 2620:1ec:c11::200: seq=7 ttl=54 time=168.856 ms
64 bytes from 2620:1ec:c11::200: seq=8 ttl=54 time=123.394 ms
64 bytes from 2620:1ec:c11::200: seq=9 ttl=54 time=50.861 ms
Normally I’d have you ping the actual site/service, but it looks like Docker bounces/ignores all ping requests so we can’t see if you can reach them that way. I just want to see if your internet connectivity is good and your DNS resolving is working right.
1638974072535
Here is my internet Wifi
1638974427396
information
Youpee !!
It was Window defender … A message appeared after 30 mn !!
Now WebODM is working
Thanks !!
Patrick
