Dose my parameters set wrong?
Which parameter decides filling holes?
its probably because you haven’t captured pictures from enough angles.
You might want to see if you can increase the minimum number of tie-points parameter, and maybe disable the reduce-image parameter for tie-point extraction to see if you can generate any tie-points for those parts of the images, but as @manand881 said, you might simply not have enough visibility there.
