Where is webodm Local files(windows 10)
hello
that i can use this application now,and i put it on my owner computer,but I found that my memory is decreasing, even if I delete the task on the web front end, it still fails to restore the memory space,
i think that maybe i need delete that upload picture by myself but i cant find it out
Attach a few of my pictures I am very satisfied with them they will appear in my paper
完成
完成图
Glad you’re having success processing!
Did you install via Docker?
yes,i use the lastest docker dosktop
The latest releases (v1.9.11+) will no longer keep the all.zip file on disk, but will generate it on the fly now. This should save you a lot of space in your docker volumes!
