Windows10
I have installed docker and ODM images and can successfully run WebODM. Now I need a way to run ODM automatically. I choose to run using the CMD command. But I can’t find the document about how to use the CMD command. Only some examples can be found
The ODM commandline is self-documenting, so if you run it without an argument it should show help.
We also have our documentation here: https://docs.opendronemap.org
I can’t find the CMD command tutorial in the address you gave me. Can you specify which chapter it is in?
Are you using the ODM command program from GitHub?
If so, the current best documentation is to execute it on the Command Prompt and it will show you the syntax and arguments you can use with it.
