What parameters might I tweak to extract more features?
These three images are C2C products using the same optimized pmf on the pc. The first image is a Metashape product that I would like to get close to using WebODM. My goal is to create a hag that I can later threshold, so the above-ground features are crucial. The second image is a WebODM product with the features and pc set to “high”, and the last image is a WebODM product with the features and pc set to “ultra”. It is surprising to see almost no above-ground points from the ultra. Am I missing a vital parameter in the processing?
Cheers,
Josh “tech dilettante”
This is what you’re looking for.
https://docs.opendronemap.org/arguments/pc-filter/
What do you recommend? Should I set it to 0?
Start with that and see what you get.
