What may cause this scrappy result?
I have been using ODM for several months and it works on most of my images.
I used to take photos at an altitude between 50 to 200 meters (using a programmed DJI mavic 2, overlapping rate at about 70%), and ODM always produces acceptable result.
Recently I am trying to stitch photos taken at 30 meters high. This time, however, ODM produces scrappy results (like the image below).
I have tired multiple times, and it seems that this only happens when the height is below 50 meters.
Why would this happen? And how can I fix this?
FOV likely too narrow to get adequate tie points at that height. Try using a slight forward camera angle, wider lens, and/or possibly changing minimum tie point parameters in ODM.
You might be losing overlap too, since you’re flying lower. You’ll need more photos at that altitude.
Eh @Saijin_Naib I just re-read our answers and I was just re-stating what you said. Don’t mind me; I’m slow haha.
All good, you clarified another way to approach a possible fix that I didn’t explicitly state :slight_smile:
I lowered the tie points parameter and it worked.
Thanks, guys.
Can i ask which parameter is it?
I can’t see any Tie Points Parameter in WebODM configuration.
It’s min-num-features
