I’m new to the forum. I have trouble specifying --proj
argument (PROJ4 string for the transformation of the outputs) correctly; so far I’ve tried the following (either quoted, double-quoted, or unquoted):
+proj=tmerc +lat_0=0 +lon_0=173 +k=0.9996 +x_0=1600000 +y_0=10000000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
EPSG:2193
epsg:2193
The full proj4 string results in an immediate error:
usage: run.py [options] <project name>
run.py: error: unrecognized arguments: +lat_0=0 +lon_0=173 +k=0.9996 +x_0=1600000 +y_0=10000000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs'
…while the EPSG:xxxx
shorthand is not recognised:
[ERROR] Could not set projection. Please use a proj4 string
File "/code/opendm/types.py", line 183, in set_projection
return Proj(projstring)
File "/usr/lib/python2.7/dist-packages/pyproj/__init__.py", line 358, in __new__
return _proj.Proj.__new__(self, projstring)
File "_proj.pyx", line 84, in _proj.Proj.__cinit__ (_proj.c:1170)
RuntimeError: projection not named
I’m reading the list of arguments from a file. I’ve looked through the source code but couldn’t find the definitions. I’d appreciate a hint.
I’m running ODM in a Singularity container.
Thanks.
