What different between node and MicMac node?
I just realized there are two different node on the webOdm. It is very confused for beginners. Since most of my projects failed, some maybe results in different node, some maybe results in unsupported cameras.
What different between these two?
There are two processing engines in the ecosystem: NodeODM and NodeMICMAC. NodeMICMAC is based on the venerable MICMAC photogrammetry project and is interesting for that reason, but NodeODM is the default and recommended approach under most circumstances.
I am unclear how you got a WebODM with two nodes. It’s not the default behavior and has to be specially invoked. You should probably always use the NodeODM version. In fact I would go so far as to recommend deleting that node from your WebODM instance.
