What are the integer data in UserData column of output from webODM?
The odm_georeferenced_model.las output from webODM reconstruction of RGB drone images (not lidar) has all zeros in the classification column (even though my input settings set pc-classify = TRUE). The UserData column has non-zero data. I do not know what these UserData represent? They look like they might classification of ground, vegetation, etc?
Sample output in the odm_georeferenced_model.las is pasted below
[email protected][[“UserData”]]
[1] 2 2 2 3 3 2 2 3 2 2 4 3 2 2 3 2 2 3 2 3 2 2 2 2 2 2 3 2 2 2 5 2 2 3 6 2 2 2 7 2 2 2 2 2 2 3 2 2 3 3 2 2
[53] 2 3 2 2 2 4 3 5 3 2 2 3 2 3 2 6
For non-lidar sensors, I am assuming, that the output from webODM is not going to have any classification?
Thank you any help or guidance you can provide,
The --pc-classify tag is influenced by the Simple Morphological Filter that is used to generate the DTM. I think you’ll find with the default settings you’re mostly going to have Unclassified/0 for most of it, unless your dataset has some really dynamic elevation and structure changes.
https://docs.opendronemap.org/arguments/pc-classify/
As for the userdata column, I am not sure at the moment.
Yes, to better understand smrf, check out the PDAL documentation on it:
https://pdal.io/stages/filters.smrf.html
UserData contains the number of views (cameras) that a point has been seen by. It’s mostly used internally to generate our coverage report diagram.
Thank you everyone for the great help in explaining what the UserData column data in the output .las file means, and the classification values for photogrammetry.
