What are the correct way to set node's max concurrency and max images?
I’ve seen people mention using --max_concurrency and --max_images when starting a node, but when I try I just get “unknown flag: --max_images” and “unknown flag: --max_concurrency” errors.
E.g.
$ docker run -dp 3001:3000 --runtime=nvidia --env NVIDIA_VISIBLE_DEVICES=0 --max_concurrency 20 --max_images 4000 --name nodeodmgpu01 opendronemap/nodeodm:gpu
What am I doing wrong here?
Shouldn’t you use split?
I’m using split in the task settings, and these settings are to dimension the nodes in a cluster.
I found that (as others have discussed) in a cluster the split threshold is interpreted liberally. E.g. in my last test with ~7300 images and split=2000 it actually allocated ~7200 images to the first node in the cluster and ~2500 images to the second node, which effectively nullified the benefit of having the additional node.
Have you tried lovering the split value?
Try:
docker run -dp 3001:3000 --runtime=nvidia --env NVIDIA_VISIBLE_DEVICES=0 --name nodeodmgpu01 opendronemap/nodeodm:gpu --max_concurrency 20 --max_images 4000
Thanks Piero, that works!
