I had a question regarding a 3D model/DEM models it seems that the 3D mapping models and DEM models are bowled and that is not how the elevation is, attached is what i am referring to, please help me! thanks!
Above is the bowled one
Below is the one more accurate.
What is your sensor and flying pattern? This is a lens calibration issue, which OpenDroneMap is better than most everything at, except for a certain subset of sensors and flight patterns.
Flight pattern is just the normal lawn mower style, as far as the sensor it is a Mavic Air 2. If it makes a difference I flew the Bottom image at 90 degrees and the top at 80 degrees pitch
What’s your flight speed? The Mavic air doesn’t have a global sensor, so stopping at each point is recommended, at least until we add a rolling shutter correction to OpenDroneMap.
13MPH @ 285ft – Shutter speed was at 1/800s to 1/1100s I have an idea that might’ve caused this I am checking into atm will lyk if it was the issue, Thanks for the help btw. I did run the images through lightroom and ran detail enhancement on it and It could cause this im sure…
Just ran the un-enhanced images (the originals before running them in lightroom) they turned out as they should. I’m pretty sure something in lightroom messed with the images.
Yeah wasn’t something I was expecting as all the images kept meta data etc… I was just thinking what I did differently compared to the one that turned out great, and the only differences were I ran detail enhancement on the images in lightroom so idek lol. Tried the untouched originals and they turned out good, But thanks for the help I think running at 85 degrees rather than 80 would turn out a bit better results what do you think?
It did actually, it said it was a built-in profile though so IDK if it actually applied a correction or if it was just saying it had a built-in profile on the camera that was used
