Well, I'm at my wits end. . . .
I’ve read through several posts on here similar to the error I’m having, and I can’t seem to correct the issue. Basically, I cannot get any process to complete unless I’ve got less than 50 images. Otherwise it always ends with a “Code 1”. Even if I change the min-num-features, down sample the images, or try to run fast orthophoto only. . . .
I’ve got a quad core PC with 64 bit architecture and 8gigs RAM.
Here’s the images: https://photos.app.goo.gl/cRaVGZqUJEcEAwVg9
Here’s the output:
[INFO] Initializing OpenDroneMap app - Fri Oct 19 02:08:22 2018
[DEBUG] Loading dataset from: /var/www/data/032d67ab-1ad1-4581-9a27-4c2e2e230970/images
[DEBUG] /var/www/data/032d67ab-1ad1-4581-9a27-4c2e2e230970/images
[DEBUG] Loaded DJI_0271.JPG | camera: hasselblad l1d-20c | dimensions: 2048 x 1365 | focal: 28.0 | ccd: 25.4 | lat: 45.435671723 | lon: -122.803269711 | alt: -101525213.5
[DEBUG] Loaded DJI_0307.JPG | camera: hasselblad l1d-20c | dimensions: 2048 x 1365 | focal: 28.0 | ccd: 25.4 | lat: 45.4391004932 | lon: -122.811892919 | alt: -101525211.7
… removed due to character limits …
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm detect_features /var/www/data/032d67ab-1ad1-4581-9a27-4c2e2e230970/opensfm
2018-10-19 02:08:51,574 INFO: Extracting ROOT_HAHOG features for image DJI_0271.JPG
2018-10-19 02:08:52,387 INFO: Extracting ROOT_HAHOG features for image DJI_0307.JPG
2018-10-19 02:09:00,385 DEBUG: Found 10027 points in 8.62796592712s
2018-10-19 02:09:01,022 DEBUG: Found 10523 points in 8.40542793274s
2018-10-19 02:09:02,807 INFO: Extracting ROOT_HAHOG features for image DJI_0319.JPG
2018-10-19 02:09:03,545 INFO: Extracting ROOT_HAHOG features for image DJI_0310.JPG
2018-10-19 02:09:12,115 DEBUG: Found 10070 points in 9.12604403496s
2018-10-19 02:09:12,947 DEBUG: Found 10408 points in 9.23612499237s
2018-10-19 02:09:14,645 INFO: Extracting ROOT_HAHOG features for image DJI_0294.JPG
2018-10-19 02:09:15,535 INFO: Extracting ROOT_HAHOG features for image DJI_0322.JPG
2018-10-19 02:09:23,407 DEBUG: Found 10113 points in 8.6103079319s
2018-10-19 02:09:25,135 DEBUG: Found 10027 points in 9.41735291481s
2018-10-19 02:09:26,118 INFO: Extracting ROOT_HAHOG features for image DJI_0309.JPG
2018-10-19 02:09:27,609 INFO: Extracting ROOT_HAHOG features for image DJI_0341.JPG
2018-10-19 02:09:35,037 DEBUG: Found 10447 points in 8.75352501869s
2018-10-19 02:09:36,319 DEBUG: Found 10394 points in 8.5329310894s
2018-10-19 02:09:37,461 INFO: Extracting ROOT_HAHOG features for image DJI_0291.JPG
2018-10-19 02:09:39,401 INFO: Extracting ROOT_HAHOG features for image DJI_0300.JPG
2018-10-19 02:09:47,029 DEBUG: Found 10161 points in 9.43149805069s
2018-10-19 02:09:48,554 DEBUG: Found 10011 points in 8.97133803368s
2018-10-19 02:09:49,265 INFO: Extracting ROOT_HAHOG features for image DJI_0302.JPG
2018-10-19 02:09:51,025 INFO: Extracting ROOT_HAHOG features for image DJI_0290.JPG
2018-10-19 02:09:58,632 DEBUG: Found 10015 points in 9.18962001801s
2018-10-19 02:10:00,072 DEBUG: Found 10163 points in 8.8962430954s
2018-10-19 02:10:02,531 INFO: Extracting ROOT_HAHOG features for image DJI_0311.JPG
2018-10-19 02:10:03,351 INFO: Extracting ROOT_HAHOG features for image DJI_0357.JPG
2018-10-19 02:10:12,893 DEBUG: Found 10369 points in 10.1262190342s
2018-10-19 02:10:13,564 DEBUG: Found 9921 points in 10.0121660233s
2018-10-19 02:10:14,928 INFO: Extracting ROOT_HAHOG features for image DJI_0347.JPG
2018-10-19 02:10:16,853 INFO: Extracting ROOT_HAHOG features for image DJI_0358.JPG
2018-10-19 02:10:24,434 DEBUG: Found 10052 points in 9.39854001999s
2018-10-19 02:10:26,529 DEBUG: Found 9983 points in 9.50352907181s
2018-10-19 02:10:26,809 INFO: Extracting ROOT_HAHOG features for image DJI_0273.JPG
2018-10-19 02:10:28,880 INFO: Extracting ROOT_HAHOG features for image DJI_0298.JPG
2018-10-19 02:10:36,276 DEBUG: Found 9904 points in 9.31909513474s
2018-10-19 02:10:38,058 DEBUG: Found 10053 points in 8.9699420929s
2018-10-19 02:10:39,109 INFO: Extracting ROOT_HAHOG features for image DJI_0286.JPG
2018-10-19 02:10:40,419 INFO: Extracting ROOT_HAHOG features for image DJI_0279.JPG
2018-10-19 02:10:48,599 DEBUG: Found 9887 points in 9.1714220047s
2018-10-19 02:10:49,914 DEBUG: Found 10119 points in 9.32241606712s
2018-10-19 02:10:52,047 INFO: Extracting ROOT_HAHOG features for image DJI_0321.JPG
2018-10-19 02:10:52,828 INFO: Extracting ROOT_HAHOG features for image DJI_0293.JPG
2018-10-19 02:11:01,737 DEBUG: Found 10045 points in 9.49895596504s
2018-10-19 02:11:02,519 DEBUG: Found 10107 points in 9.52536201477s
2018-10-19 02:11:04,431 INFO: Extracting ROOT_HAHOG features for image DJI_0328.JPG
2018-10-19 02:11:04,962 INFO: Extracting ROOT_HAHOG features for image DJI_0268.JPG
2018-10-19 02:11:12,253 DEBUG: Found 10269 points in 7.10054802895s
2018-10-19 02:11:12,439 DEBUG: Found 9980 points in 7.79946613312s
2018-10-19 02:11:13,876 INFO: Extracting ROOT_HAHOG features for image DJI_0349.JPG
2018-10-19 02:11:14,579 INFO: Extracting ROOT_HAHOG features for image DJI_0316.JPG
2018-10-19 02:11:19,991 DEBUG: Found 10123 points in 5.88188290596s
2018-10-19 02:11:20,174 DEBUG: Found 10338 points in 5.48822498322s
2018-10-19 02:11:21,199 INFO: Extracting ROOT_HAHOG features for image DJI_0338.JPG
2018-10-19 02:11:21,890 INFO: Extracting ROOT_HAHOG features for image DJI_0324.JPG
2018-10-19 02:11:25,991 DEBUG: Found 10372 points in 4.69309401512s
2018-10-19 02:11:26,733 DEBUG: Found 10138 points in 4.73821997643s
2018-10-19 02:11:27,292 INFO: Extracting ROOT_HAHOG features for image DJI_0337.JPG
2018-10-19 02:11:27,997 INFO: Extracting ROOT_HAHOG features for image DJI_0275.JPG
2018-10-19 02:11:32,130 DEBUG: Found 10316 points in 4.74284982681s
2018-10-19 02:11:32,741 DEBUG: Found 10150 points in 4.65590596199s
2018-10-19 02:11:33,382 INFO: Extracting ROOT_HAHOG features for image DJI_0362.JPG
2018-10-19 02:11:33,957 INFO: Extracting ROOT_HAHOG features for image DJI_0331.JPG
2018-10-19 02:11:38,201 DEBUG: Found 10144 points in 4.72409796715s
2018-10-19 02:11:38,845 DEBUG: Found 10027 points in 4.79372000694s
2018-10-19 02:11:40,079 INFO: Extracting ROOT_HAHOG features for image DJI_0301.JPG
2018-10-19 02:11:40,831 INFO: Extracting ROOT_HAHOG features for image DJI_0332.JPG
2018-10-19 02:11:44,627 DEBUG: Found 9999 points in 4.46418905258s
2018-10-19 02:11:45,590 DEBUG: Found 10043 points in 4.6749458313s
2018-10-19 02:11:45,842 INFO: Extracting ROOT_HAHOG features for image DJI_0330.JPG
2018-10-19 02:11:46,787 INFO: Extracting ROOT_HAHOG features for image DJI_0360.JPG
2018-10-19 02:11:50,937 DEBUG: Found 9961 points in 5.00573301315s
2018-10-19 02:11:51,896 DEBUG: Found 9964 points in 5.01376795769s
2018-10-19 02:11:52,151 INFO: Extracting ROOT_HAHOG features for image DJI_0284.JPG
2018-10-19 02:11:53,129 INFO: Extracting ROOT_HAHOG features for image DJI_0278.JPG
2018-10-19 02:11:56,887 DEBUG: Found 9913 points in 4.64143514633s
2018-10-19 02:11:57,940 DEBUG: Found 10181 points in 4.7100110054s
2018-10-19 02:11:58,111 INFO: Extracting ROOT_HAHOG features for image DJI_0277.JPG
2018-10-19 02:11:59,255 INFO: Extracting ROOT_HAHOG features for image DJI_0305.JPG
2018-10-19 02:12:02,861 DEBUG: Found 10157 points in 4.65077400208s
2018-10-19 02:12:04,002 DEBUG: Found 10254 points in 4.58509206772s
2018-10-19 02:12:04,137 INFO: Extracting ROOT_HAHOG features for image DJI_0283.JPG
2018-10-19 02:12:06,411 INFO: Extracting ROOT_HAHOG features for image DJI_0326.JPG
2018-10-19 02:12:08,335 DEBUG: Found 9854 points in 4.04319906235s
2018-10-19 02:12:09,719 INFO: Extracting ROOT_HAHOG features for image DJI_0340.JPG
2018-10-19 02:12:11,134 DEBUG: Found 10040 points in 4.63077497482s
2018-10-19 02:12:12,369 INFO: Extracting ROOT_HAHOG features for image DJI_0267.JPG
2018-10-19 02:12:14,488 DEBUG: Found 10412 points in 4.66226696968s
2018-10-19 02:12:16,031 INFO: Extracting ROOT_HAHOG features for image DJI_0313.JPG
2018-10-19 02:12:17,158 DEBUG: Found 10267 points in 4.6980919838s
2018-10-19 02:12:18,421 INFO: Extracting ROOT_HAHOG features for image DJI_0261.JPG
2018-10-19 02:12:20,683 DEBUG: Found 10371 points in 4.56063079834s
2018-10-19 02:12:21,990 INFO: Extracting ROOT_HAHOG features for image DJI_0285.JPG
2018-10-19 02:12:23,084 DEBUG: Found 10015 points in 4.55919790268s
2018-10-19 02:12:24,475 INFO: Extracting ROOT_HAHOG features for image DJI_0296.JPG
2018-10-19 02:12:26,640 DEBUG: Found 9979 points in 4.55796599388s
2018-10-19 02:12:27,868 INFO: Extracting ROOT_HAHOG features for image DJI_0359.JPG
2018-10-19 02:12:28,999 DEBUG: Found 10091 points in 4.43827199936s
2018-10-19 02:12:30,619 INFO: Extracting ROOT_HAHOG features for image DJI_0299.JPG
2018-10-19 02:12:32,428 DEBUG: Found 9902 points in 4.4541079998s
2018-10-19 02:12:33,700 INFO: Extracting ROOT_HAHOG features for image DJI_0350.JPG
2018-10-19 02:12:35,423 DEBUG: Found 10009 points in 4.70707297325s
2018-10-19 02:12:36,738 INFO: Extracting ROOT_HAHOG features for image DJI_0297.JPG
2018-10-19 02:12:38,487 DEBUG: Found 10123 points in 4.68962287903s
2018-10-19 02:12:39,911 INFO: Extracting ROOT_HAHOG features for image DJI_0336.JPG
2018-10-19 02:12:41,520 DEBUG: Found 10089 points in 4.68549203873s
2018-10-19 02:12:42,697 INFO: Extracting ROOT_HAHOG features for image DJI_0363.JPG
2018-10-19 02:12:44,531 DEBUG: Found 10134 points in 4.50328803062s
2018-10-19 02:12:45,814 INFO: Extracting ROOT_HAHOG features for image DJI_0348.JPG
2018-10-19 02:12:47,702 DEBUG: Found 10196 points in 4.90918707848s
2018-10-19 02:12:49,420 INFO: Extracting ROOT_HAHOG features for image DJI_0355.JPG
2018-10-19 02:12:51,268 DEBUG: Found 10042 points in 5.3469440937s
2018-10-19 02:12:52,541 INFO: Extracting ROOT_HAHOG features for image DJI_0270.JPG
2018-10-19 02:12:54,217 DEBUG: Found 10046 points in 4.689234972s
2018-10-19 02:12:55,627 INFO: Extracting ROOT_HAHOG features for image DJI_0269.JPG
2018-10-19 02:12:57,390 DEBUG: Found 10159 points in 4.76181387901s
2018-10-19 02:12:58,613 INFO: Extracting ROOT_HAHOG features for image DJI_0333.JPG
2018-10-19 02:13:00,368 DEBUG: Found 10302 points in 4.65324091911s
2018-10-19 02:13:01,629 INFO: Extracting ROOT_HAHOG features for image DJI_0315.JPG
2018-10-19 02:13:03,251 DEBUG: Found 10135 points in 4.53631210327s
2018-10-19 02:13:04,576 INFO: Extracting ROOT_HAHOG features for image DJI_0281.JPG
2018-10-19 02:13:06,316 DEBUG: Found 10351 points in 4.59538698196s
2018-10-19 02:13:07,661 INFO: Extracting ROOT_HAHOG features for image DJI_0265.JPG
2018-10-19 02:13:09,597 DEBUG: Found 9863 points in 4.92338395119s
2018-10-19 02:13:11,292 INFO: Extracting ROOT_HAHOG features for image DJI_0288.JPG
2018-10-19 02:13:12,559 DEBUG: Found 10145 points in 4.80794596672s
2018-10-19 02:13:14,000 INFO: Extracting ROOT_HAHOG features for image DJI_0361.JPG
2018-10-19 02:13:15,855 DEBUG: Found 10004 points in 4.47602510452s
2018-10-19 02:13:18,175 DEBUG: Found 10014 points in 4.06246113777s
2018-10-19 02:13:19,603 INFO: Extracting ROOT_HAHOG features for image DJI_0266.JPG
2018-10-19 02:13:19,706 INFO: Extracting ROOT_HAHOG features for image DJI_0346.JPG
2018-10-19 02:13:24,136 DEBUG: Found 10188 points in 4.44360804558s
2018-10-19 02:13:24,265 DEBUG: Found 10206 points in 4.47759795189s
2018-10-19 02:13:25,709 INFO: Extracting ROOT_HAHOG features for image DJI_0323.JPG
2018-10-19 02:13:25,868 INFO: Extracting ROOT_HAHOG features for image DJI_0342.JPG
2018-10-19 02:13:30,821 DEBUG: Found 10136 points in 5.02804279327s
2018-10-19 02:13:31,108 DEBUG: Found 10377 points in 5.14362597466s
2018-10-19 02:13:32,063 INFO: Extracting ROOT_HAHOG features for image DJI_0339.JPG
2018-10-19 02:13:32,354 INFO: Extracting ROOT_HAHOG features for image DJI_0356.JPG
2018-10-19 02:13:36,776 DEBUG: Found 10324 points in 4.61671805382s
2018-10-19 02:13:37,188 DEBUG: Found 9934 points in 4.74474000931s
2018-10-19 02:13:38,067 INFO: Extracting ROOT_HAHOG features for image DJI_0264.JPG
2018-10-19 02:13:38,484 INFO: Extracting ROOT_HAHOG features for image DJI_0344.JPG
2018-10-19 02:13:42,867 DEBUG: Found 10265 points in 4.70331311226s
2018-10-19 02:13:43,340 DEBUG: Found 10261 points in 4.75852489471s
2018-10-19 02:13:44,068 INFO: Extracting ROOT_HAHOG features for image DJI_0318.JPG
2018-10-19 02:13:45,097 INFO: Extracting ROOT_HAHOG features for image DJI_0312.JPG
2018-10-19 02:13:49,422 DEBUG: Found 10122 points in 5.26616096497s
2018-10-19 02:13:50,711 DEBUG: Found 10403 points in 5.517141819s
2018-10-19 02:13:51,281 INFO: Extracting ROOT_HAHOG features for image DJI_0287.JPG
2018-10-19 02:13:52,196 INFO: Extracting ROOT_HAHOG features for image DJI_0304.JPG
2018-10-19 02:13:56,153 DEBUG: Found 9984 points in 4.78986310959s
2018-10-19 02:13:57,158 DEBUG: Found 10168 points in 4.86716389656s
2018-10-19 02:13:57,484 INFO: Extracting ROOT_HAHOG features for image DJI_0329.JPG
2018-10-19 02:13:58,381 INFO: Extracting ROOT_HAHOG features for image DJI_0263.JPG
2018-10-19 02:14:02,139 DEBUG: Found 9971 points in 4.56936478615s
2018-10-19 02:14:03,287 DEBUG: Found 10101 points in 4.81382894516s
2018-10-19 02:14:03,678 INFO: Extracting ROOT_HAHOG features for image DJI_0274.JPG
2018-10-19 02:14:04,797 INFO: Extracting ROOT_HAHOG features for image DJI_0303.JPG
2018-10-19 02:14:08,357 DEBUG: Found 9968 points in 4.56033706665s
2018-10-19 02:14:09,480 DEBUG: Found 10022 points in 4.55814909935s
2018-10-19 02:14:09,757 INFO: Extracting ROOT_HAHOG features for image DJI_0308.JPG
2018-10-19 02:14:10,768 INFO: Extracting ROOT_HAHOG features for image DJI_0320.JPG
2018-10-19 02:14:14,534 DEBUG: Found 10453 points in 4.66772389412s
2018-10-19 02:14:15,900 DEBUG: Found 10090 points in 5.03756785393s
2018-10-19 02:14:16,262 INFO: Extracting ROOT_HAHOG features for image DJI_0317.JPG
2018-10-19 02:14:17,330 INFO: Extracting ROOT_HAHOG features for image DJI_0351.JPG
2018-10-19 02:14:21,652 DEBUG: Found 10232 points in 5.30261802673s
2018-10-19 02:14:22,624 DEBUG: Found 10056 points in 5.18177700043s
2018-10-19 02:14:22,888 INFO: Extracting ROOT_HAHOG features for image DJI_0335.JPG
2018-10-19 02:14:23,946 INFO: Extracting ROOT_HAHOG features for image DJI_0280.JPG
2018-10-19 02:14:28,588 DEBUG: Found 10115 points in 5.58391690254s
2018-10-19 02:14:29,603 DEBUG: Found 9902 points in 5.57213807106s
2018-10-19 02:14:29,945 INFO: Extracting ROOT_HAHOG features for image DJI_0343.JPG
2018-10-19 02:14:33,641 DEBUG: Found 10388 points in 3.59821391106s
2018-10-19 02:14:35,867 INFO: Extracting ROOT_HAHOG features for image DJI_0325.JPG
2018-10-19 02:14:37,985 INFO: Extracting ROOT_HAHOG features for image DJI_0345.JPG
2018-10-19 02:14:40,169 DEBUG: Found 9990 points in 4.21573805809s
2018-10-19 02:14:41,467 INFO: Extracting ROOT_HAHOG features for image DJI_0353.JPG
2018-10-19 02:14:42,612 DEBUG: Found 10252 points in 4.52649712563s
2018-10-19 02:14:44,286 INFO: Extracting ROOT_HAHOG features for image DJI_0292.JPG
2018-10-19 02:14:46,598 DEBUG: Found 10085 points in 5.03039503098s
2018-10-19 02:14:47,821 INFO: Extracting ROOT_HAHOG features for image DJI_0306.JPG
2018-10-19 02:14:49,335 DEBUG: Found 10156 points in 4.905616045s
2018-10-19 02:14:51,152 INFO: Extracting ROOT_HAHOG features for image DJI_0352.JPG
2018-10-19 02:14:53,318 DEBUG: Found 10402 points in 5.40026402473s
2018-10-19 02:14:55,059 INFO: Extracting ROOT_HAHOG features for image DJI_0354.JPG
2018-10-19 02:14:57,042 DEBUG: Found 10069 points in 5.78995203972s
2018-10-19 02:14:58,465 INFO: Extracting ROOT_HAHOG features for image DJI_0276.JPG
2018-10-19 02:15:00,647 DEBUG: Found 10045 points in 5.42295694351s
2018-10-19 02:15:02,077 INFO: Extracting ROOT_HAHOG features for image DJI_0272.JPG
2018-10-19 02:15:03,991 DEBUG: Found 10179 points in 5.42608094215s
2018-10-19 02:15:05,445 INFO: Extracting ROOT_HAHOG features for image DJI_0282.JPG
2018-10-19 02:15:07,351 DEBUG: Found 9896 points in 5.18610978127s
2018-10-19 02:15:08,752 INFO: Extracting ROOT_HAHOG features for image DJI_0314.JPG
2018-10-19 02:15:10,807 DEBUG: Found 9827 points in 5.24491405487s
2018-10-19 02:15:12,287 INFO: Extracting ROOT_HAHOG features for image DJI_0364.JPG
2018-10-19 02:15:14,376 DEBUG: Found 10393 points in 5.51667118073s
2018-10-19 02:15:17,112 DEBUG: Found 10102 points in 4.70902585983s
2018-10-19 02:15:20,547 INFO: Extracting ROOT_HAHOG features for image DJI_0262.JPG
2018-10-19 02:15:20,925 INFO: Extracting ROOT_HAHOG features for image DJI_0334.JPG
2018-10-19 02:15:26,172 DEBUG: Found 10050 points in 5.53111791611s
2018-10-19 02:15:26,700 DEBUG: Found 10141 points in 5.65110087395s
2018-10-19 02:15:27,730 INFO: Extracting ROOT_HAHOG features for image DJI_0327.JPG
2018-10-19 02:15:28,630 INFO: Extracting ROOT_HAHOG features for image DJI_0295.JPG
2018-10-19 02:15:32,341 DEBUG: Found 9900 points in 4.54193806648s
2018-10-19 02:15:33,130 DEBUG: Found 10030 points in 4.43389797211s
2018-10-19 02:15:33,511 INFO: Extracting ROOT_HAHOG features for image DJI_0289.JPG
2018-10-19 02:15:37,454 DEBUG: Found 10027 points in 3.84525108337s
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm match_features /var/www/data/032d67ab-1ad1-4581-9a27-4c2e2e230970/opensfm
2018-10-19 02:15:39,100 INFO: Matching 0 image pairs
2018-10-19 02:15:39,734 INFO: Matching DJI_0327.JPG - 1 / 104
2018-10-19 02:15:39,998 INFO: Matching DJI_0338.JPG - 2 / 104
2018-10-19 02:15:39,999 INFO: Matching DJI_0349.JPG - 3 / 104
2018-10-19 02:15:40,005 INFO: Matching DJI_0269.JPG - 4 / 104
2018-10-19 02:15:40,017 INFO: Matching DJI_0270.JPG - 5 / 104
2018-10-19 02:15:40,034 INFO: Matching DJI_0305.JPG - 6 / 104
2018-10-19 02:15:40,045 INFO: Matching DJI_0268.JPG - 7 / 104
2018-10-19 02:15:40,056 INFO: Matching DJI_0285.JPG - 8 / 104
2018-10-19 02:15:40,069 INFO: Matching DJI_0323.JPG - 9 / 104
2018-10-19 02:15:40,080 INFO: Matching DJI_0274.JPG - 10 / 104
2018-10-19 02:15:40,090 INFO: Matching DJI_0261.JPG - 11 / 104
2018-10-19 02:15:40,101 INFO: Matching DJI_0278.JPG - 12 / 104
2018-10-19 02:15:40,112 INFO: Matching DJI_0334.JPG - 13 / 104
2018-10-19 02:15:40,133 INFO: Matching DJI_0295.JPG - 14 / 104
2018-10-19 02:15:40,144 INFO: Matching DJI_0301.JPG - 15 / 104
2018-10-19 02:15:40,163 INFO: Matching DJI_0312.JPG - 16 / 104
2018-10-19 02:15:40,220 INFO: Matching DJI_0358.JPG - 17 / 104
2018-10-19 02:15:40,230 INFO: Matching DJI_0275.JPG - 18 / 104
2018-10-19 02:15:40,241 INFO: Matching DJI_0282.JPG - 19 / 104
2018-10-19 02:15:40,252 INFO: Matching DJI_0280.JPG - 20 / 104
2018-10-19 02:15:40,264 INFO: Matching DJI_0311.JPG - 21 / 104
2018-10-19 02:15:40,275 INFO: Matching DJI_0309.JPG - 22 / 104
2018-10-19 02:15:40,285 INFO: Matching DJI_0299.JPG - 23 / 104
2018-10-19 02:15:40,297 INFO: Matching DJI_0267.JPG - 24 / 104
2018-10-19 02:15:40,308 INFO: Matching DJI_0286.JPG - 25 / 104
2018-10-19 02:15:40,319 INFO: Matching DJI_0304.JPG - 26 / 104
2018-10-19 02:15:40,331 INFO: Matching DJI_0314.JPG - 27 / 104
2018-10-19 02:15:40,340 INFO: Matching DJI_0316.JPG - 28 / 104
2018-10-19 02:15:40,365 INFO: Matching DJI_0263.JPG - 29 / 104
2018-10-19 02:15:40,374 INFO: Matching DJI_0317.JPG - 30 / 104
2018-10-19 02:15:40,385 INFO: Matching DJI_0364.JPG - 31 / 104
2018-10-19 02:15:40,397 INFO: Matching DJI_0307.JPG - 32 / 104
2018-10-19 02:15:40,406 INFO: Matching DJI_0281.JPG - 33 / 104
2018-10-19 02:15:40,419 INFO: Matching DJI_0294.JPG - 34 / 104
2018-10-19 02:15:40,430 INFO: Matching DJI_0357.JPG - 35 / 104
2018-10-19 02:15:40,442 INFO: Matching DJI_0302.JPG - 36 / 104
2018-10-19 02:15:40,453 INFO: Matching DJI_0279.JPG - 37 / 104
2018-10-19 02:15:40,463 INFO: Matching DJI_0313.JPG - 38 / 104
2018-10-19 02:15:40,474 INFO: Matching DJI_0276.JPG - 39 / 104
2018-10-19 02:15:40,487 INFO: Matching DJI_0353.JPG - 40 / 104
2018-10-19 02:15:40,499 INFO: Matching DJI_0332.JPG - 41 / 104
2018-10-19 02:15:40,508 INFO: Matching DJI_0336.JPG - 42 / 104
2018-10-19 02:15:40,520 INFO: Matching DJI_0264.JPG - 43 / 104
2018-10-19 02:15:40,530 INFO: Matching DJI_0337.JPG - 44 / 104
2018-10-19 02:15:40,542 INFO: Matching DJI_0287.JPG - 45 / 104
2018-10-19 02:15:40,552 INFO: Matching DJI_0362.JPG - 46 / 104
2018-10-19 02:15:40,564 INFO: Matching DJI_0315.JPG - 47 / 104
2018-10-19 02:15:40,575 INFO: Matching DJI_0266.JPG - 48 / 104
2018-10-19 02:15:40,586 INFO: Matching DJI_0346.JPG - 49 / 104
2018-10-19 02:15:40,596 INFO: Matching DJI_0335.JPG - 50 / 104
2018-10-19 02:15:40,609 INFO: Matching DJI_0347.JPG - 51 / 104
2018-10-19 02:15:40,622 INFO: Matching DJI_0343.JPG - 52 / 104
2018-10-19 02:15:40,638 INFO: Matching DJI_0291.JPG - 53 / 104
2018-10-19 02:15:40,649 INFO: Matching DJI_0293.JPG - 54 / 104
2018-10-19 02:15:40,661 INFO: Matching DJI_0354.JPG - 55 / 104
2018-10-19 02:15:40,671 INFO: Matching DJI_0306.JPG - 56 / 104
2018-10-19 02:15:40,682 INFO: Matching DJI_0318.JPG - 57 / 104
2018-10-19 02:15:40,692 INFO: Matching DJI_0331.JPG - 58 / 104
2018-10-19 02:15:40,703 INFO: Matching DJI_0342.JPG - 59 / 104
2018-10-19 02:15:40,714 INFO: Matching DJI_0288.JPG - 60 / 104
2018-10-19 02:15:40,725 INFO: Matching DJI_0271.JPG - 61 / 104
2018-10-19 02:15:40,736 INFO: Matching DJI_0319.JPG - 62 / 104
2018-10-19 02:15:40,748 INFO: Matching DJI_0262.JPG - 63 / 104
2018-10-19 02:15:40,760 INFO: Matching DJI_0356.JPG - 64 / 104
2018-10-19 02:15:40,772 INFO: Matching DJI_0359.JPG - 65 / 104
2018-10-19 02:15:40,784 INFO: Matching DJI_0303.JPG - 66 / 104
2018-10-19 02:15:40,795 INFO: Matching DJI_0340.JPG - 67 / 104
2018-10-19 02:15:40,808 INFO: Matching DJI_0339.JPG - 68 / 104
2018-10-19 02:15:40,819 INFO: Matching DJI_0265.JPG - 69 / 104
2018-10-19 02:15:40,830 INFO: Matching DJI_0330.JPG - 70 / 104
2018-10-19 02:15:40,843 INFO: Matching DJI_0361.JPG - 71 / 104
2018-10-19 02:15:40,855 INFO: Matching DJI_0300.JPG - 72 / 104
2018-10-19 02:15:40,867 INFO: Matching DJI_0297.JPG - 73 / 104
2018-10-19 02:15:40,878 INFO: Matching DJI_0344.JPG - 74 / 104
2018-10-19 02:15:40,890 INFO: Matching DJI_0351.JPG - 75 / 104
2018-10-19 02:15:40,900 INFO: Matching DJI_0292.JPG - 76 / 104
2018-10-19 02:15:40,912 INFO: Matching DJI_0348.JPG - 77 / 104
2018-10-19 02:15:40,921 INFO: Matching DJI_0341.JPG - 78 / 104
2018-10-19 02:15:40,935 INFO: Matching DJI_0350.JPG - 79 / 104
2018-10-19 02:15:40,943 INFO: Matching DJI_0352.JPG - 80 / 104
2018-10-19 02:15:40,956 INFO: Matching DJI_0363.JPG - 81 / 104
2018-10-19 02:15:40,967 INFO: Matching DJI_0320.JPG - 82 / 104
2018-10-19 02:15:40,978 INFO: Matching DJI_0289.JPG - 83 / 104
2018-10-19 02:15:40,990 INFO: Matching DJI_0290.JPG - 84 / 104
2018-10-19 02:15:41,002 INFO: Matching DJI_0355.JPG - 85 / 104
2018-10-19 02:15:41,014 INFO: Matching DJI_0321.JPG - 86 / 104
2018-10-19 02:15:41,025 INFO: Matching DJI_0345.JPG - 87 / 104
2018-10-19 02:15:41,038 INFO: Matching DJI_0325.JPG - 88 / 104
2018-10-19 02:15:41,050 INFO: Matching DJI_0284.JPG - 89 / 104
2018-10-19 02:15:41,060 INFO: Matching DJI_0324.JPG - 90 / 104
2018-10-19 02:15:41,074 INFO: Matching DJI_0328.JPG - 91 / 104
2018-10-19 02:15:41,085 INFO: Matching DJI_0308.JPG - 92 / 104
2018-10-19 02:15:41,097 INFO: Matching DJI_0329.JPG - 93 / 104
2018-10-19 02:15:41,106 INFO: Matching DJI_0333.JPG - 94 / 104
2018-10-19 02:15:41,118 INFO: Matching DJI_0326.JPG - 95 / 104
2018-10-19 02:15:41,128 INFO: Matching DJI_0283.JPG - 96 / 104
2018-10-19 02:15:41,140 INFO: Matching DJI_0360.JPG - 97 / 104
2018-10-19 02:15:41,150 INFO: Matching DJI_0277.JPG - 98 / 104
2018-10-19 02:15:41,162 INFO: Matching DJI_0296.JPG - 99 / 104
2018-10-19 02:15:41,173 INFO: Matching DJI_0273.JPG - 100 / 104
2018-10-19 02:15:41,186 INFO: Matching DJI_0298.JPG - 101 / 104
2018-10-19 02:15:41,198 INFO: Matching DJI_0322.JPG - 102 / 104
2018-10-19 02:15:41,212 INFO: Matching DJI_0272.JPG - 103 / 104
2018-10-19 02:15:41,223 INFO: Matching DJI_0310.JPG - 104 / 104
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm create_tracks /var/www/data/032d67ab-1ad1-4581-9a27-4c2e2e230970/opensfm
2018-10-19 02:15:41,677 INFO: reading features
2018-10-19 02:15:46,083 DEBUG: Merging features onto tracks
2018-10-19 02:15:46,084 DEBUG: Good tracks: 0
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm reconstruct /var/www/data/032d67ab-1ad1-4581-9a27-4c2e2e230970/opensfm
2018-10-19 02:15:46,481 INFO: Starting incremental reconstruction
2018-10-19 02:15:46,481 INFO: 0 partial reconstructions in total.
plasm.execute(niter=1)
File “/code/scripts/run_opensfm.py”, line 141, in process
image_scale = gsd.image_scale_factor(args.orthophoto_resolution, tree.opensfm_reconstruction)
File “/code/opendm/gsd.py”, line 15, in image_scale_factor
gsd = opensfm_reconstruction_average_gsd(reconstruction_json)
File “/usr/local/lib/python2.7/dist-packages/repoze/lru/init.py”, line 348, in cached_wrapper
val = func(*args, **kwargs)
File “/code/opendm/gsd.py”, line 59, in opensfm_reconstruction_average_gsd
raise FileNotFoundError(reconstruction_json + " does not exist.")
NameError: global name ‘FileNotFoundError’ is not defined
At 8gigs of RAM, you are hitting a real ceiling. Can you allocate more scratch space to act as RAM? It might run a bit slower for larger batches of images, but it should complete.
You can also try out the split-merge approach which is somewhat experimental, but effective: http://docs.opendronemap.org/large.html
I think you have the Mavic 2 Pro GPS altitude issue as well… are you running WebODM on a windows box? You say you were able to process a smaller set of these images?
You’re absolutely right, yawstick. I was having altitude value issues previously. But I wrote a python script that edits the image exif data to correct it. I forgot to do that with this batch of photos, so I bet that’s part of the issue here. Will edit them and retry.
However, despite correcting the altitude values, I still cannot process more than about 50 images. I think smathermather is right that I’m running into RAM issues.
I tried processing some of your images… had to rewrite the exif data to get it to run at all. was able to process 11 images but failed with 21… was just guessing at your actual altitude.
