[03]: Hyper-V Virtual Ethernet Adapter
[04]: Hyper-V Virtual Ethernet Adapter
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Detected Windows 10 with Hyper-V support
Initializing console…
Checking if current user is in docker-users group
User is in docker-users group
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
Client: Docker Engine - Community
Version: 19.03.4
API version: 1.40
Go version: go1.12.10
Git commit: 9013bf5
Built: Thu Oct 17 23:44:48 2019
OS/Arch: windows/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.4
API version: 1.40 (minimum version 1.12)
Git commit: 9013bf5
Built: Thu Oct 17 23:50:38 2019
OS/Arch: linux/amd64
Experimental: false
containerd:
Version: v1.2.10
GitCommit: b34a5c8af56e510852c35414db4c1f4fa6172339
runc:
Version: 1.0.0-rc8+dev
GitCommit: 3e425f80a8c931f88e6d94a8c831b9d5aa481657
docker-init:
Version: 0.18.0
GitCommit: fec3683
Press Start WebODM to launch
Checking for MS Edge Zone…
Zones are OK
C:\WebODM Manager>cd WebODM/
C:\WebODM Manager\WebODM>docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up
Starting db …
Starting node-odm …
Starting broker …
Starting worker …
Starting webapp …
e[5Ae[2K
Starting db … e[31mfailede[0m
e[5Be[4Ae[2K
Starting node-odm … e[31mfailede[0m
e[4Be[3Ae[2K
Starting broker … e[31mfailede[0m
e[3Be[2Ae[2K
Starting worker … e[31mfailede[0m
e[2Be[1Ae[2K
Starting webapp … e[31mfailede[0m
e[1BNo containers to start
Pulling db (opendronemap/webodm_db:)…
Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on 192.168.65.1:53: read udp 192.168.65.3:58038->192.168.65.1:53: i/o timeout
C:\WebODM Manager\WebODM>exit 1
Error: docker-compose exited with code: 1
