Hi!
I’d installed WebODM around January and had used for a very very brief while. Had successfully managed to set it up on my system with help from @pierotofy here. I’d installed it using Docker Toolbox since I’ve got Windows 10 Home.
Now I haven’t used it since then. I tried running it today, but it won’t start up. Here’s the error I’m getting after I try to start the script.
Error checking TLS connection: Error checking and/or regenerating the certs: There was an error validating certificates for host "192.168.99.100:2376": dial tcp 192.168.99.100:2376: connectex: No connection could be made because the target machine actively refused it.
You can attempt to regenerate them using 'docker-machine regenerate-certs [name]'.
Be advised that this will trigger a Docker daemon restart which might stop running containers.
/"""""""""""""""""\___/ ===
\______ o __/
\ \ __/
\____\_______/
docker is configured to use the default machine with IP 192.168.99.100
For help getting started, check out the docs at https://docs.docker.com
Start interactive shell
[email protected] MINGW64 ~
$ cd WebODM/
[email protected] MINGW64 ~/WebODM (master)
$ ./webodm.sh start
Checking for docker... OK
Checking for git... OK
Checking for python... OK
Checking for pip... OK
Checking for docker-compose... OK
Starting WebODM...
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up
Starting db ...
Starting node-odm-1 ...
Starting webapp ... error
ERROR: for db (2, 'WaitNamedPipe', 'The system cannot find the file specified.')
ERROR: for node-odm-1 (2, 'WaitNamedPipe', 'The system cannot find the file specified.')
ERROR: Windows named pipe error: The system cannot find the file specified. (code: 2)
I found this here Issues · OpenDroneMap/WebODM · GitHub
However, this isn’t working either and is giving me an error.
I would like to start afresh and would also like to update to version 0.4.
What would be the best way to go about this?
Would I have to remove everything and start over including Docker?
Thanks!
