WebODM won't start on Pop!_OS (Ubuntu based) - permissions issues?
Hello!
I have been running WebODM a bit on my MacBook Pro - but today a built a new PC for this (Ryzen 5 3600, 32GB ram, etc). Running Pop!_OS (Ubuntu based) and tried to install WebODM now but I ran into an issue. When I try to start WebODM I get this (first good, then bad) below. What do you think? Big thanks in advance!
benjamin@pop-os:~/WebODM$ ./webodm.sh start
Checking for docker...   OK
Checking for git...   OK
Checking for docker-compose...   OK
Starting WebODM...
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up
Starting db         ...
Starting broker     ...
Starting node-odm-1 ...
Starting worker     ... error
Starting webapp     ... error
ERROR: for broker  ('Connection aborted.', PermissionError(13, 'Permission denied'))
ERROR: for db  ('Connection aborted.', PermissionError(13, 'Permission denied'))
ERROR: for node-odm-1  ('Connection aborted.', PermissionError(13, 'Permission denied'))
ERROR: Couldn't connect to Docker daemon at http+docker://localhost - is it running?
If it's at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
I got it working by adding myself to the Docker group - all good now.
