WebODM Windows 1.9.1 Build 19
I am also having issues with build 19, may or may not be related to Webdom 1.19.1 Build 19 - WebODM - OpenDroneMap Community.
Blockquote
“Booting WebODM 1.9.1 build 19…”
“Trying to connect to NodeODM localhost:29301…”
“nodeodm: info: Authentication using SimpleToken\r\n”
“nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\n”
“nodeodm: info: No tasks dump found\r\n”
“nodeodm: info: Checking for orphaned directories to be removed…\r\n”
“nodeodm: info: Server has started on port 29301\r\n”
“Connected to NodeODM 2.1.7”
“redis-server: . \n .-__ ''-._ \n _.- . . ‘’-._ Redis 3.2.100 (00000000/0) 64 bit\n .- .-```. ```\\/ _.,_ ''-._ \n ( ' , .-` | `, ) Running in standalone mode\n |`-._`-...-` __...-.-.|’_.-'| Port: 29379\n | -. ._ / _.-' | PID: 13764\n -._ -._ -./ .-’ .-’ \n |-._-. -.__.-' _.-'_.-'| \n | -.-._ _.-'_.-' | http://redis.io \n -._ -._-..-’.-’ .-’ \n |-._-. -.__.-' _.-'_.-'| \n | -.-._ _.-'_.-' | \n -._ -._-..-’_.-’ _.-’ \n -._ -..-’ _.-’ \n -._ _.-' \n -..-’ \n\n[13764] 10 Jun 08:03:34.454 # Server started, Redis version 3.2.100\n”
“redis-server: \n\n=== REDIS BUG REPORT START: Cut & paste starting from here ===\nRedis version: 3.2.100\n[13764] 10 Jun 08:03:34.454 # === ASSERTION FAILED OBJECT CONTEXT ===\n[13764] 10 Jun 08:03:34.454 # Object type: 0\n[13764] 10 Jun 08:03:34.454 # Object encoding: 0\n[13764] 10 Jun 08:03:34.454 # Object refcount: 1\n[13764] 10 Jun 08:03:34.454 # Object raw string len: 0\n[13764] 10 Jun 08:03:34.454 # Object raw string content: “”\n[13764] 10 Jun 08:03:34.454 # === ASSERTION FAILED ===\n[13764] 10 Jun 08:03:34.454 # ==> …\src\db.c:164 ‘retval == DICT_OK’ is not true\n[13764] 10 Jun 08:03:34.454 # — EXCEPTION_ACCESS_VIOLATION\n[13764] 10 Jun 08:03:34.454 # — STACK TRACE\nredis-server.exe!((null):0)(0x0014E7C0, 0x0014FF60, 0x40028F20, 0x4013A7F8)\nredis-server.exe!((null):0)(0x00000000, 0x00000000, 0x00000000, 0x00000002)\n”
“redis-server: KERNELBASE.dll!UnhandledExceptionFilter((null):0)(0x0014E870, 0x6CBF662C, 0x00000000, 0x0014E808)\nntdll.dll!memset((null):0)(0x6CC22A24, 0x6CAB0000, 0x0014E870, 0x6CAE0E7B)\nntdll.dll!_C_specific_handler((null):0)(0x00000000, 0x0014ED70, 0x0014F430, 0x00000000)\nntdll.dll!_chkstk((null):0)(0x00000000, 0x0014ED70, 0x0014F430, 0x00000000)\nntdll.dll!RtlRaiseException((null):0)(0x00000001, 0x40170C6A, 0x9306BEC0, 0x005B08E0)\nntdll.dll!KiUserExceptionDispatcher((null):0)(0x9306BEC0, 0x40170C50, 0x4016FC40, 0x000000A4)\nredis-server.exe!KiUserExceptionDispatcher((null):0)(0x00000000, 0x00000000, 0x0014F810, 0x9306BEC0)\nredis-server.exe!KiUserExceptionDispatcher((null):0)(0x5E9C21C8, 0x00000002, 0x0000000A, 0x00000000)\nredis-server.exe!KiUserExceptionDispatcher((null):0)(0x60C229C6, 0x40178288, 0x0014F340, 0x0014F360)\nredis-server.exe!KiUserExceptionDispatcher((null):0)(0x00000000, 0x60C229C6, 0x00578380, 0x00000002)\nredis-server.exe!KiUserExceptionDispatcher((null):0)(0x00000000, 0x00000000, 0x00000000, 0x00000000)\nredis-server.exe!KiUserExceptionDispatcher((null):0)(0x00000000, 0x00000000, 0x00000000, 0x00000000)\nKERNEL32.DLL!BaseThreadInitThunk((null):0)(0x00000000, 0x00000000, 0x00000000, 0x00000000)\nntdll.dll!RtlUserThreadStart((null):0)(0x00000000, 0x00000000, 0x00000000, 0x00000000)\nntdll.dll!RtlUserThreadStart((null):0)(0x00000000, 0x00000000, 0x00000000, 0x00000000)\n”
“redis-server: [13764] 10 Jun 08:03:34.455 # — INFO OUTPUT\n# Server\r\nredis_version:3.2.100\r\nredis_git_sha1:00000000\r\nredis_git_dirty:0\r\nredis_build_id:dd26f1f93c5130ee\r\nredis_mode:standalone\r\nos:Windows \r\narch_bits:64\r\nmultiplexing_api:WinSock_IOCP\r\nprocess_id:13764\r\nrun_id:8d70d04377e5066bfdad713c60396c53902f7353\r\ntcp_port:29379\r\nuptime_in_seconds:0\r\nuptime_in_days:0\r\nhz:10\r\nlru_clock:12724678\r\nexecutable:D:\WebODM\resources\app\apps\redis\redis-server\r\nconfig_file:D:\WebODM\resources\app\apps\redis\redis.conf\r\n\r\n# Clients\r\nconnected_clients:0\r\nclient_longest_output_list:0\r\nclient_biggest_input_buf:0\r\nblocked_clients:0\r\n\r\n# Memory\r\nused_memory:894840\r\nused_memory_human:873.87K\r\nused_memory_rss:0\r\nused_memory_rss_human:0B\r\nused_memory_peak:894840\r\nused_memory_peak_human:873.87K\r\ntotal_system_memory:0\r\ntotal_system_memory_human:0B\r\nused_memory_lua:37888\r\nused_memory_lua_human:37.00K\r\nmaxmemory:0\r\nmaxmemory_human:0B\r\nmaxmemory_policy:noeviction\r\nmem_fragmentation_ratio:0.00\r\nmem_allocator:jemalloc-3.6.0\r\n\r\n# Persistence\r\nloading:1\r\nrdb_changes_since_last_save:0\r\nrdb_bgsave_in_progress:0\r\nrdb_last_save_time:1623337414\r\nrdb_last_bgsave_status:ok\r\nrdb_last_bgsave_time_sec:-1\r\nrdb_current_bgsave_time_sec:-1\r\naof_enabled:0\r\naof_rewrite_in_progress:0\r\naof_rewrite_scheduled:0\r\naof_last_rewrite_time_sec:-1\r\naof_current_rewrite_time_sec:-1\r\naof_last_bgrewrite_status:ok\r\naof_last_write_status:ok\r\nloading_start_time:jd\r\nloading_total_bytes:1623337414\r\nloading_loaded_bytes:2858628\r\nloading_loaded_perc:0.00\r\nloading_eta_seconds:jd\r\n\r\n# Stats\r\ntotal_connections_received:0\r\ntotal_commands_processed:0\r\ninstantaneous_ops_per_sec:0\r\ntotal_net_input_bytes:0\r\ntotal_net_output_bytes:0\r\ninstantaneous_input_kbps:0.00\r\ninstantaneous_output_kbps:0.00\r\nrejected_connections:0\r\nsync_full:0\r\nsync_partial_ok:0\r\nsync_partial_err:0\r\nexpired_keys:0\r\nevicted_keys:0\r\nkeyspace_hits:0\r\nkeyspace_misses:0\r\npubsub_channels:0\r\npubsub_patterns:0\r\nlatest_fork_usec:0\r\nmigrate_cached_sockets:0\r\n\r\n# Replication\r\nrole:master\r\nconnected_slaves:0\r\nmaster_repl_offset:0\r\nrepl_backlog_active:0\r\nrepl_backlog_size:1048576\r\nrepl_backlog_first_byte_offset:0\r\nrepl_backlog_histlen:0\r\n\r\n# CPU\r\nused_cpu_sys:0.03\r\nused_cpu_user:0.03\r\nused_cpu_sys_children:0.00\r\nused_cpu_user_children:0.00\r\n\r\n# Commandstats\r\n\r\n# Cluster\r\ncluster_enabled:0\r\n\r\n# Keyspace\r\ndb0:keys=1,expires=0,avg_ttl=0\r\n[13764] 10 Jun 08:03:34.455 # \n=== REDIS BUG REPORT END. Make sure to include from START to END. ===\n\n Please report this bug by following the instructions at:\n\n http://github.com/MSOpenTech/redis/wiki/Submitting-an-Issue\n\n Suspect RAM error? Use redis-server --test-memory to verify it.\n\n\n”
“redis-server: exited with code 3221225477”
“(node:9996) UnhandledPromiseRejectionWarning: Error: Exit code: 3221225477\n at ChildProcess. (D:\WebODM\resources\app\utils.js:63:19)\n at ChildProcess.emit (events.js:210:5)\n at maybeClose (internal/child_process.js:1021:16)\n at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)”
“(node:9996) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)”
“(node:9996) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.”
Windows native installer ( I believe - have been using new releases WebODM & ODM 2.5.3)
Cheers,
Jeff
Strange. Can you try to remove C:\WebODM\resources\app\apps\redis\dump.rdb and restart?
A post was merged into an existing topic: Webdom 1.19.1 Build 19
Hello Piero!
That did the trick!
Thank you sir!
Jeff
strange, your posting is a near exact replica of my notifications, which first occurred this morning(day 4 of using the software) … your fix didn’t fix mine … odd … I may have suffered internet loss, untimely shutdown or both(it happened while I was cleaning) … this is when my problems began.
I have a Liveno (sp), 16GB 2.9 ghz, Windows 10 …
I’m considering uninstalling(removing?), the whole shooting match and re-installing using Gimp2.99.6 setup.exe(?), but I think I’ll see if an easily understandable remedy might present itself.
I’ve considered the Firewall issue, but I’m not sure allowing WebODM to clear it. Am I allowing WebODM.com to clear or maybe Node??? to clear(I’m sorry, but my short-term memory is compromised … lol … BTW, I live on a sailboat=intermittent internet issues …
Truthfully, I’ve had 40+ years of learning, relearning, relearning and relearning of one computer thing or another, and I find myself somewhat at wits end … my Bifocal’s split causes me to hit the wrong keys often, and is about to be the straw that breaks my aching back.
Very simple, easy or explicit ideas might be what I need …
Now I know why old men are crotchetty … hmm
Thanks in advance …
John
Sorry to hear that you’re having some difficulty with WebODM.
Can you try to Check For Updates from within WebODM and update to the latest build?
