sudo ./webodm.sh start
Getting the following error. Can anyone help pls.
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
File “/snap/docker/796/bin/docker-compose”, line 33, in
sys.exit(load_entry_point(‘docker-compose==1.25.5’, ‘console_scripts’, ‘docker-compose’)())
File “/snap/docker/796/lib/python3.6/site-packages/compose/cli/main.py”, line 72, in main
command()
File “/snap/docker/796/lib/python3.6/site-packages/compose/cli/main.py”, line 125, in perform_command
project = project_from_options(’.’, options)
File “/snap/docker/796/lib/python3.6/site-packages/compose/cli/command.py”, line 47, in project_from_options
environment = Environment.from_env_file(override_dir or project_dir, environment_file)
File “/snap/docker/796/lib/python3.6/site-packages/compose/config/environment.py”, line 77, in from_env_file
instance = _initialize()
File “/snap/docker/796/lib/python3.6/site-packages/compose/config/environment.py”, line 72, in _initialize
return cls(env_vars_from_file(env_file_path))
File “/snap/docker/796/lib/python3.6/site-packages/compose/config/environment.py”, line 43, in env_vars_from_file
with contextlib.closing(codecs.open(filename, ‘r’, ‘utf-8-sig’)) as fileobj:
File “/snap/docker/796/usr/lib/python3.6/codecs.py”, line 897, in open
file = builtins.open(filename, mode, buffering)
PermissionError: [Errno 13] Permission denied: ‘./.env’
command()
