Hi !
Just started testing out WebODM, it’s really amazing !! Super easy to install, even easier to use, and great results out of the box !!!
I’m wondering whether there is a way to automatically spin up workers on demand ? I searched a bit in the doc and here, but didn’t find any mention of this.
The issue is that if you install WebODM in the cloud (Amazon EC2 for example), you need a relatively big instance to compute tasks, which is a waste of money when not running any task. Also, it would be awesome to dynamically add a worker for each new task, so that you can run jobs in parallel without any queue.
I guess it must be doable, since as far as I understood, it’s possible to have remote workers, and most cloud providers have an api to manage instances.
It is possible to limit the issue by using a provider that supports automatic vertical scaling (like jelastic), but that still limits to one task at a time, and the idle worker still wastes a little bit of resources.
Cheers,
Olivier
