Adding to the WebODM website the capability to edit the simultaneous queue count.
I do not see an easy way to change the default value for simultaneous tasks running.
Thank you.
Thank you.
See the --default-nodes
flag from webodm.sh
: https://github.com/OpenDroneMap/WebODM/blob/master/webodm.sh#L136 which accomplishes the same result.
Piero,
Will that allow me to change how many simultaneous tasks I’m running on the same node?
Thank you.
No, but it will create more nodes each with a separate queue of 1, which has the same net-effect.
Piero, I tried the following.
sudo ./webodm.sh start --default-nodes 10
I still only have one node listed, and only one task running. Everything else is waiting “Queued”:
Try restart
instead of start
That worked. Thank you!!
