./webodm.sh start run error
Hi guys.
Has anyone else experienced this error?
webapp | Checking for celery… OK
webapp | Scheduler is not running.
webapp | /webodm/start.sh: line 117: syntax error near unexpected token }' webapp | /webodm/start.sh: line 117: }’
webapp exited with code 2
Sorry for the trouble.
No, this seems new.
Have you modified anything in your install?
No. I just run ./webodm.sh update
Hmm…
Could you please start with giving me a bit more information about your system?
Operating System and Version
eg: Windows 11, MacOS 12.4, Ubuntu Linux 22.04LTS, etc…
Hardware Specifications
eg: 32GB RAM, i7-6700k, NVIDIA GTX 1050TI OC, 1TB SSD, etc…
WebODM Install Method
WebODM/ODM Version
eg: WebODM v1.9.14 Build 64, ODM v2.8.7, etc…
Procesing Node
eg: Automatic, Lightning, local (node-odm-1), etc…
Screenshots demonstrating the issue/behavior/error messages
Windows 10
32GB RAM, Intel(R) Xeon(R) CPU E5-2666 v3 @ 2.90GHz, AMD Radeon RX 6400, 1TB SSD
Docker
WebODM/ODM Version
I don’t know how to confirm this information without being able to run the application
Procesing Node
Local (node-odm-1)
I am just running into the same trouble … at the moment I do not manage to start WebODM.
Happened right after updating …
Syntax of start.sh seems to be broken …
And then it loops exactly like in the screenshot above.
Running latest WebODM scripts from Github on Linux Mint 21.1 with Docker CE.
We made a whoopsie :rofl:
Even with the change, the error persists
Has been changed both manually and with ./webodm.sh update run
Hmm, again: same here.
I first thought it might take a moment to sync the commit, but at the moment the error is still the same.
Okay, it works again :sweat_smile:
I only pulled the WebODM scripts from Github, but running a ./webodm.sh update fixed the issue.
Thx for the quick response @pierotofy
Working here too.
Thks guys.
