Hey everyone. Question. I have a dell server that I just installed WebODM too. Everything is installed and working. I myself can access the web login to access the dashboard. I had a question regarding other members of my team who are outside of my network to process against my node. For example, I have a team member who is going to upload a project and start processing. I want to be able to give him a way to connect to the web login to process via the web dashboard, instead of using the desktop client. Is this possible? Or are they going to have to buy the desktop client and add the node there?
Yes however you will be exposing your machine to the internet, so a good idea to be sure and have the firewall enabled and set up and --ssl and --hostname options enabled. if the machine is behind a NAT device forwarding port 80 and 443 will be required. Also setting up a dynamic host through services such as noip is also recommended.
