I only have node-odm-1 in my options, on watching tutorials I see there is and Auto option, this doesn’t show in my version of the app. Am I missing something as a new user? I’m not sure if this is where I should be posting this question so apologies if I am starting a new topic already covered.
We’ve changed the Node selection logic to remove Automatic as it was causing problems when people trialed Lightning and were out of credits.
Having only node-odm-1 is the correct behavior unless you’ve also signed into Lightning or added other nodes locally or on your home network.
Thanks for the help, is there a need to add other nodes and where do you find them to add. I am planning just simple orthophotos and maybe a few 3D models.
When you are starting out, no, adding nodes is a more advanced workflow.
Lightning could be useful as a faster node or for larger datasets. Keep in mind it is a paid service.
