I have been having trouble processing an image dataset.
Image data set is from a Photogrammetry mission run with the DJI Zenmuse L1, (Run as a Photogrammetry mission with the 20MP camera, with 80%/80% overlap.)
I have tried to process it multiple times and the error message is basically the same but references a different “no such file or directory” Full console output below, but the part that is different each time is this actual .npz file referenced.
If i process the images as Fast Ortho it works, but any other option always fails. As a last ditch I got a trial version of DJI Terra Pro and it was able to process the dataset so I am pretty sure that the photos themselves are ok.
FileNotFoundError: [Errno 2] No such file or directory: ‘D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\opensfm\features\DJI_20220828133334_0181_Zenmuse-L1-mission.JPG.features.npz’
[INFO] running “D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm” create_tracks “D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\opensfm”
[INFO] Initializing ODM 2.8.6 - Mon Aug 29 15:12:47 2022
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] auto_boundary: True
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 2.0
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 32
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] name: a50cef40-90db-4d59-9c7c-5bbb1410c15f
[INFO] no_gpu: False
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 2.0
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: high
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] project_path: D:\WebODM\resources\app\apps\NodeODM\data
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: ['odm_postprocess']
[INFO] resize_to: 2048
[INFO] rolling_shutter: False
[INFO] skip_3dmodel: False
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\images
[INFO] Loading images database: D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\images.json
[INFO] Found 601 usable images
[INFO] Coordinates file already exist: D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\odm_georeferencing\coords.txt
[INFO] Model geo file already exist: D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\odm_georeferencing\odm_georeferencing_model_geo.txt
[INFO] Parsing SRS header: WGS84 UTM 19N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[WARNING] D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\opensfm\image_list.txt already exists, not rerunning OpenSfM setup
[WARNING] D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\opensfm\exif already exists, not rerunning photo to metadata
[WARNING] Detect features already done: D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\opensfm\features exists
[INFO] running "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm" match_features "D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\opensfm"
2022-08-29 15:12:50,855 INFO: Computing pair matching with 32 processes
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\\opensfm_main.py", line 25, in
commands.command_runner(
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\command_runner.py", line 38, in command_runner
command.run(data, args)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\command.py", line 13, in run
self.run_impl(data, args)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\match_features.py", line 13, in run_impl
match_features.run_dataset(dataset)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\actions\match_features.py", line 14, in run_dataset
pairs_matches, preport = matching.match_images(data, {}, images, images)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py", line 56, in match_images
match_images_with_pairs(data, config_override, exifs, pairs),
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py", line 80, in match_images_with_pairs
matches = context.parallel_map(match_unwrap_args, args, processes, jobs_per_process)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\context.py", line 58, in parallel_map
res = Parallel(batch_size=batch_size)(delayed(func)(arg) for arg in args)
File "D:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\joblib\parallel.py", line 1061, in __call__
self.retrieve()
File "D:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\joblib\parallel.py", line 940, in retrieve
File "multiprocessing\pool.py", line 768, in get
File "multiprocessing\pool.py", line 125, in worker
File "D:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\joblib\_parallel_backends.py", line 595, in __call__
return self.func(*args, **kwargs)
File "D:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\joblib\parallel.py", line 262, in __call__
return [func(*args, **kwargs)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py", line 210, in match_unwrap_args
matches = match(im1, im2, camera1, camera2, data, config_override, pose)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py", line 579, in match
p1, p2, matches, matcher_type = _match_descriptors_impl(
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\matching.py", line 353, in _match_descriptors_impl
features_data1 = feature_loader.instance.load_all_data(
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\feature_loading.py", line 109, in load_all_data
features_data = self._load_all_data_masked(data, image)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\feature_loading.py", line 160, in _load_all_data_masked
features_data = self._load_all_data_unmasked(data, image)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\feature_loading.py", line 154, in _load_all_data_unmasked
return self._load_features_nocache(data, image)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\feature_loading.py", line 201, in _load_features_nocache
features_data = data.load_features(image)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py", line 318, in load_features
with self.io_handler.open(features_filepath, "rb") as f:
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\io.py", line 1462, in open
return open(*args, **kwargs)
FileNotFoundError: [Errno 2] No such file or directory: 'D:\\WebODM\\resources\\app\\apps\\NodeODM\\data\\a50cef40-90db-4d59-9c7c-5bbb1410c15f\\opensfm\\features\\DJI_20220828133334_0181_Zenmuse-L1-mission.JPG.features.npz'
[INFO] running "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm" create_tracks "D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\opensfm"
2022-08-29 15:12:52,871 INFO: reading features
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\create_tracks.py", line 13, in run_impl
create_tracks.run_dataset(dataset)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\actions\create_tracks.py", line 12, in run_dataset
features, colors, segmentations, instances = tracking.load_features(
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\tracking.py", line 29, in load_features
features_data = dataset.load_features(im)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py", line 319, in load_features
return features.FeaturesData.from_file(f, self.config)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\features.py", line 140, in from_file
s = np.load(fileobject, allow_pickle=False)
File "D:\WebODM\resources\app\apps\ODM\venv\lib\site-packages\numpy\lib\npyio.py", line 445, in load
raise ValueError("Cannot load file containing pickled data "
ValueError: Cannot load file containing pickled data when allow_pickle=False
[INFO] running "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm" reconstruct "D:\WebODM\resources\app\apps\NodeODM\data\a50cef40-90db-4d59-9c7c-5bbb1410c15f\opensfm"
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\commands\reconstruct.py", line 14, in run_impl
reconstruct.run_dataset(dataset)
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\actions\reconstruct.py", line 9, in run_dataset
tracks_manager = data.load_tracks_manager()
File "D:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\dataset.py", line 406, in load_tracks_manager
return pymap.TracksManager.instanciate_from_file(self._tracks_manager_file(filename))
RuntimeError: Can't read tracks manager file
