When I am using webODM to produce 3D models of buildings I cannot get it to produce the sides of the buildings. I have even trying taking photos of the sides of the building with my drone while holding it and yet this does not seem to help. Any thoughts?
If you enable the Task Output panel in WebODM and copy/paste that log, that helps.
Just from looking at the imagery, you have a LOT of shadow/underexposed areas under the roof overhangs, even at ground level. I think that’s not helping finding tiepoints on the walls.
cameras on it looks like the camera shots of the side of the building do not have the correct altitude as they are very high up when they were actually taken at the ground level.
Better light would likely help, but I’m not sure how tenable that is for the building’s sides. Maybe at around solar noon you’ll have minimal shadowing on each side?
You also might need to do manual exposure adjustment on the ground-level photos to keep the walls properly exposed.
Let us know how it goes. You’re in uncharted territory for me as I’ve yet to mix aerial and terrestrial survey. Gives me something to practice in the coming months…
