WebODM not reading EXIF tags in task process
I have a phantom 4 pro and I’ve been doing some tests maps, and recently I’ve received the following error.
“An orthophoto could not be generated. To generate one, make sure GPS information is embedded in the EXIF tags of your images, or use a Ground Control Points (GCP) file.”
I am not sure why as I was able to create a successful task and create an orthoimage my first time using WebODM.
I have confirmed in windows explorer that the exif info does exist in the photos
Any thoughts?
I just was able to get it to work. I had updated the WebODM manager between tasks and didn’t realize the exif option had to clicked to true. I was able to make a quick orthophoto successfully. Will test on a full 3D model.
