“Booting WebODM 1.9.12 build 55…”
“Trying to connect to NodeODM localhost:29301…”
“nodeodm: info: Authentication using SimpleToken\r\n”
“nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\n”
“nodeodm: info: Initialized 2 tasks\r\n”
“nodeodm: info: Checking for orphaned directories to be removed…\r\n”
“nodeodm: info: Server has started on port 29301\r\n”
“Connected to NodeODM 2.2.0”
“redis-server: . \n .-__ ''-._ \n _.-
. ‘’-._ Redis 3.2.100 (00000000/0) 64 bit\n .- .-```. ```\\/ _.,_ ''-._ \n ( ' , .-` | `, ) Running in standalone mode\n |`-._`-...-` __...-.
-.|’_.-'| Port: 29379\n |
-. ._ / _.-' | PID: 22028\n
-._ -._
-./ .-’ .-’ \n |-._
-. -.__.-' _.-'_.-'| \n |
-.-._ _.-'_.-' | http://redis.io \n
-._ -._
-..-’.-’ .-’ \n |-._
-.-._ _.-'_.-' | \n
-._ -._
-..-’_.-’ _.-’ \n -._
-..-’ _.-’ \n -._ _.-' \n
-..-’ \n\n[22028] 11 May 14:37:08.224 # Server started, Redis version 3.2.100\n”
“redis-server: [22028] 11 May 14:37:08.293 * DB loaded from disk: 0.069 seconds\n[22028] 11 May 14:37:08.293 * The server is now ready to accept connections on port 29379\n”
“Trying to connect to postgres localhost:29543…”
“D:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: server starting\r\n”
“D:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: exited with code 0”
“D:\WebODM\resources\app\apps\pgsql/bin/psql: psql: could not connect to server: Connection refused (0x0000274D/10061)\r\n\tIs the server running on host “localhost” (::1) and accepting\r\n\tTCP/IP connections on port 29543?\r\ncould not connect to server: Connection refused (0x0000274D/10061)\r\n\tIs the server running on host “localhost” (127.0.0.1) and accepting\r\n\tTCP/IP connections on port 29543?\r\n”
“D:\WebODM\resources\app\apps\pgsql/bin/psql: exited with code 2”
“Attempt 0 failed, retrying…”
“Attempt 1 failed, retrying…”
“Attempt 2 failed, retrying…”
“Attempt 3 failed, retrying…”
“Attempt 4 failed, retrying…”
“Attempt 5 failed, retrying…”
“Attempt 6 failed, retrying…”
“Attempt 7 failed, retrying…”
“Attempt 8 failed, retrying…”
“Attempt 9 failed, retrying…”
FATAL: the database system is starting up
LOG: database system was shut down at 2022-02-28 23:09:16 EST
LOG: MultiXact member wraparound protections are now enabled
LOG: database system is ready to accept connections
LOG: autovacuum launcher started
LOG: database system was interrupted; last known up at 2022-04-20 20:41:42 EDT
LOG: database system was not properly shut down; automatic recovery in progress
LOG: redo starts at 0/27CC0760
LOG: invalid record length at 0/27CEA4F0: wanted 24, got 0
LOG: redo done at 0/27CEA4C8
LOG: last completed transaction was at log time 2022-04-20 20:42:23.802664-04
LOG: received fast shutdown request
LOG: aborting any active transactions
FATAL: terminating connection due to administrator command
LOG: autovacuum launcher shutting down
LOG: shutting down
LOG: database system is shut down
LOG: database system was shut down at 2022-04-20 22:10:37 EDT
FATAL: password authentication failed for user “postgres”
DETAIL: Password does not match for user “postgres”.
Connection matched pg_hba.conf line 86: “host all all ::1/128 password”
LOG: using stale statistics instead of current ones because stats collector is not responding
WARNING: worker took too long to start; canceled
WARNING: autovacuum worker started without a worker entry
LOG: database system was interrupted; last known up at 2022-04-21 01:36:33 EDT
LOG: invalid primary checkpoint record
LOG: invalid secondary checkpoint record
PANIC: could not locate a valid checkpoint record
LOG: startup process (PID 19956) was terminated by exception 0xC0000409
HINT: See C include file “ntstatus.h” for a description of the hexadecimal value.
LOG: aborting startup due to startup process failure
LOG: startup process (PID 5236) was terminated by exception 0xC0000409
LOG: startup process (PID 13704) was terminated by exception 0xC0000409
LOG: startup process (PID 18852) was terminated by exception 0xC0000409
LOG: startup process (PID 18988) was terminated by exception 0xC0000409
LOG: startup process (PID 14416) was terminated by exception 0xC0000409
LOG: startup process (PID 21120) was terminated by exception 0xC0000409
LOG: startup process (PID 22980) was terminated by exception 0xC0000409
LOG: startup process (PID 21108) was terminated by exception 0xC0000409
LOG: startup process (PID 10932) was terminated by exception 0xC0000409
Can someone help me, i turned the firewall off and it still didnt work.
