WebODM, multiple nodes?
WebODM seems to spin up a node on startup, would it be possible to make it spin up more nodes?
Like to start N-Number of instances?
Hmm… Not sure how we can do that, yet.
More like:
Processing nodes → add new → host: this pc.
Ahhh, gotcha.
Have you tried editing/adding nodes from the Administrative UI?
I have managed to add a node on another machine on the network.
You’re not looking for distributed/split-merge, right? Just purely parallel job processing?
Nice work then!
Yes that’s right. If I got lots of cores and two small jobs it would be good to process them in parallel.
And I wonder what happens if you delete the node that’s already in WebODM, can you get it back?
