WebODM Manager can't download WebODM
Yeah, like it says in the headline WebODM Manager can’t download WebODM.
Any idea why it isn’t working?
Here’s a screenshot:
Hey @Rasmus_Sainmaa :hand: what does the “Console tab” show?
The exact same message only if I remember correctly, can’t access my laptop before tomorrow.
Here’s the console message:
                       [05]: Hyper-V Virtual Ethernet Adapter
                       [06]: Hyper-V Virtual Ethernet Adapter
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Detected Windows 10 with Hyper-V support
Initializing console…
Checking if current user is in docker-users group
User is in docker-users group
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
Client: Docker Engine - Community
Version: 18.09.2
API version: 1.39
Go version: go1.10.8
Git commit: 6247962
Built: Sun Feb 10 04:12:31 2019
OS/Arch: windows/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 18.09.2
API version: 1.39 (minimum version 1.12)
Go version: go1.10.6
Git commit: 6247962
Built: Sun Feb 10 04:13:06 2019
OS/Arch: linux/amd64
Experimental: false
Press Start WebODM to launch
Checking for MS Edge Zone…
Zones are OK
Cloning into ‘WebODM’…
fatal: unable to access ‘https://github.com/OpenDroneMap/WebODM/’: error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
Error: Could not download WebODM. Please try again later.
If you open https://github.com/OpenDroneMap/WebODM/ in your web browser, do you get any error messages?
Are you using a VPN connection, or are connected to a corporate network? Perhaps something is interfering with the SSL connection.
Github page opens okay in web browser. I am connected through a corporate network currently.
Mm, per https://github.com/desktop/desktop/issues/3165 could you try to remove the Git program from your computer (just uninstall it), then re-run the WebODM Manager setup?
I actually can’t. Is it possible to manually download the files and place them somewhere?
You can try to download https://github.com/OpenDroneMap/WebODM/archive/master.zip and place the files in c:\WebODM Manager\WebODM, but you won’t be able to use the “Update” button in the future that way.
