WebODM + Ligthning - Process hangs on "Compressing all.zip"
Hi, I’m processing 631 images using WebODM and Ligthning. Here are the settings used:
resize-to: -1, min-num-features: 32000, feature-quality: ultra, depthmap-resolution: 1000, mesh-size: 300000, mesh-octree-depth: 11, texturing-nadir-weight: 32, dtm: true, dsm: true, dem-resolution: 8, orthophoto-resolution: 1
Its an Ubuntu 20.04 computer and WebODM is running on Docker, it was intalled as per the documentation directions. On Lightnings side everything seems to be working alright.
I have downloaded all assets from Ligthning and no other problems so far.
I ran the process twice and the problem persists. I´m not sure if the problem is on my side, any ideas?
Here is the task output.
… output truncated at 500 lines …
[INFO] running pdal pipeline -i /tmp/tmpctzrrfld.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x1_y2.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpmkgnbsuc.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x1_y3.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpi2cnr2u0.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x2_y0.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp60g47dnv.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x2_y1.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp1rlsin66.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x2_y2.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpcbygyw2v.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x2_y3.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpd27iuee0.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x3_y0.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpagcuxtla.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x3_y1.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpj55nzgq3.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x3_y2.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmphf3wjwka.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x3_y3.tif (idw, radius: 0.20128535070511913, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpozoy5q0f.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x0_y0.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp9miw03fz.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x0_y1.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpwvutlx62.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x0_y2.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpgf0a6i0w.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x0_y3.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp2zgzm3oy.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x1_y0.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpcxm1538h.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x1_y1.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmphuvzxug5.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x1_y2.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp98ve31bw.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x1_y3.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp04t5hn77.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x2_y0.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmphtbo1gcf.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x2_y1.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp7q0ozrzj.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x2_y2.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpm71u9kug.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x2_y3.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmpsfo16u8l.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x3_y0.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp5wm_qj59.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x3_y1.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmp0z7mabj_.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x3_y2.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmplu08jtxu.json > /dev/null 2>&1
[INFO] Generating /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x3_y3.tif (idw, radius: 0.10064267535255957, resolution: 0.20128535070511913)
[INFO] running pdal pipeline -i /tmp/tmprwfio5qp.json > /dev/null 2>&1
[INFO] running gdalbuildvrt “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.vrt” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x0_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x0_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x0_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x0_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x1_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x1_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x1_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x1_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x2_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x2_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x2_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x2_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x3_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x3_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x3_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.40257070141023826_x3_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x0_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x0_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x0_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x0_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x1_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x1_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x1_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x1_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x2_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x2_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x2_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x2_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x3_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x3_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x3_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.20128535070511913_x3_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x0_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x0_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x0_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x0_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x1_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x1_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x1_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x1_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x2_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x2_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x2_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x2_y3.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x3_y0.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x3_y1.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x3_y2.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm_r0.10064267535255957_x3_y3.tif”
0
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] running gdal_translate -co NUM_THREADS=8 --config GDAL_CACHEMAX 45.8% /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.vrt /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.tmp.tif
Input file size is 13595, 11260
0
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] running gdal_translate -co NUM_THREADS=8 --config GDAL_CACHEMAX 45.8% -outsize 10% 0 /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.tmp.tif /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.small.tif
0
…10…20…30…40…50
…60…70…80…90…100 - done.
[INFO] running gdal_fillnodata.py -co NUM_THREADS=8 --config GDAL_CACHEMAX 45.8% -b 1 -of GTiff /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.small.tif /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.small_filled.tif
0
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] running gdalbuildvrt -resolution highest -r bilinear “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/merged.vrt” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.small_filled.tif” “/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.tmp.tif”
0…10…20…30…40…50
[INFO] running gdal_translate -co NUM_THREADS=8 -co TILED=YES -co COMPRESS=DEFLATE --config GDAL_CACHEMAX 45.8% /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/merged.vrt /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/tiles.tif
0
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] Starting smoothing…
[INFO] Smoothing iteration 1
[INFO] Completed smoothing to create …/var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm.tif in 0:01:35.176034
[INFO] Completed dtm.tif in 0:27:59.020380
[INFO] Cropping /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm.tif
[INFO] running gdalwarp -cutline /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_georeferencing/odm_georeferenced_model.bounds.gpkg -crop_to_cutline -co TILED=YES -co COMPRESS=DEFLATE -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co BIGTIFF=IF_SAFER -co NUM_THREADS=8 /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm.original.tif /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm.tif --config GDAL_CACHEMAX 45.8%
Creating output file that is 13567P x 11195L.
Processing /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm.original.tif [1/1] : 0
Using internal nodata values (e.g. -9999) for image /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm.original.tif.
Copying nodata values from source /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm.original.tif to destination /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_dem/dtm.tif.
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] Finished odm_dem stage
[WARNING] Maximum resolution set to GSD - 10.0% (4.53 cm / pixel, requested resolution was 1.0 cm / pixel)
[INFO] running /code/build/bin/odm_orthophoto -inputFiles /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_texturing_25d/odm_textured_model_geo.obj -logFile /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto_log.txt -outputFile /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto_render.tif -resolution 22.08031746411346 -outputCornerFile /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto_corners.txt
[INFO] Creating GeoTIFF
[INFO] running gdal_translate -a_ullr 275830.54159670154 3059112.1091863373 278580.18515138904 3056834.448175595 -co TILED=YES -co COMPRESS=DEFLATE -co PREDICTOR=2 -co BIGTIFF=IF_SAFER -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co NUM_THREADS=8 -a_srs “+proj=utm +zone=14 +datum=WGS84 +units=m +no_defs +type=crs” --config GDAL_CACHEMAX 48.55% --config GDAL_TIFF_INTERNAL_MASK YES /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto_render.tif /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto.tif > /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/gdal_translate_log.txt
[INFO] Cropping /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto.tif
[INFO] running gdalwarp -cutline /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_georeferencing/odm_georeferenced_model.bounds.gpkg -crop_to_cutline -co TILED=YES -co COMPRESS=DEFLATE -co PREDICTOR=2 -co BIGTIFF=IF_SAFER -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co NUM_THREADS=8 -dstalpha /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto.original.tif /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto.tif --config GDAL_CACHEMAX 48.5%
Using band 4 of source image as alpha.
Creating output file that is 60299P x 49758L.
Processing /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_orthophoto/odm_orthophoto.original.tif [1/1] : 0
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] Finished odm_orthophoto stage
[INFO] Running odm_report stage
[INFO] Wrote /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7/odm_report/shots.geojson
[INFO] Finished odm_report stage
[INFO] No more stages to run
[INFO] MMMMMMMMMMMNNNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMNNNMMMMMMMMMMM
[INFO] MMMMMMdo:…—…/sNMMMMMMMMMMMMMMMMMMMMMMMMMMNs/…—…:odMMMMMM
[INFO] MMMMy-.odNMMMMMNy//mMMMMMMMMMMMMMMMMMMMMMMm//hNMMMMMNdo.-yMMMM
[INFO] MMN/sMMMMMMMMMNNMm/yMMMMMMMMMMMMMMMMMMMMy/mMNNMMMMMMMMNs/MMM
[INFO] MM/ hMMMMMMMMNs.+MMM/ dMMMMMMMMMMMMMMMMMMh +MMM+.sNMMMMMMMMh +MM
[INFO] MN /MMMMMMNo/./mMMMMN :MMMMMMMMMMMMMMMMMM: NMMMMm/./oNMMMMMM: NM
[INFO] Mm +MMMMMN+ /MMMMMMM-MMMMMMMMMMMMMMMMMM-MMMMMMM: oNMMMMM+ mM
[INFO] MM…NMMNs./mNMMMMMMMy sMMMMMMMMMMMMMMMMMMo hMMMMMMMNm/.sNMMN-MM [INFO] MMd:mMNomMMMMMMMMMy:MMMMMMMNmmmmNMMMMMMN:hMMMMMMMMMdoNMm-dMM [INFO] MMMm:.omMMMMMMMMNh/ sdmmho/.-``-/sddh+ /hNMMMMMMMMdo.:mMMM [INFO] MMMMMd+--/osss+:-:/ :- .ym+ hmo``:-` `+:-:ossso/-:+dMMMMM [INFO] MMMMMMMNmhysosydmNMo /ds`/NMM+ hMMd..dh. sMNmdysosyhmNMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMMs .:-:``hmmN+ yNmds -:.:`-NMMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMN.-mNm- //:::. -:://: +mMd`-NMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM+ dMMN -MMNNN+ yNNNMN :MMMs sMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM`.mmmy /mmmmm/ smmmmm``mmmh :MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM``:::- ./////. -:::::` :::: -MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM:`mNNd /NNNNN+ hNNNNN .NNNy +MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMd`/MMM.`ys+//. -/+oso +MMN.`mMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMMy /o:- `oyhd/ shys+ `-:s-`hMMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMNmdhhhdmNMMM` +d+ sMMM+ hMMN:`hh- sMMNmdhhhdmNMMMMMMMM [INFO] MMMMMms:::/++//::+ho .+- /dM+ hNh- +/` -h+:://++/::/smMMMMM [INFO] MMMN+./hmMMMMMMNds- ./oso:.``:. :-``.:os+- -sdNMMMMMMmy:.oNMMM [INFO] MMm-.hMNhNMMMMMMMMNo`/MMMMMNdhyyyyhhdNMMMM+`oNMMMMMMMMNhNMh.-mMM [INFO] MM:`mMMN/-sNNMMMMMMMo yMMMMMMMMMMMMMMMMMMy sMMMMMMMNNs-/NMMm`:MM [INFO] Mm /MMMMMd/.-oMMMMMMN :MMMMMMMMMMMMMMMMMM-`MMMMMMMo-./dMMMMM/ NM [INFO] Mm /MMMMMMm:-`sNMMMMN :MMMMMMMMMMMMMMMMMM-`MMMMMNs`-/NMMMMMM/ NM [INFO] MM:`mMMMMMMMMd/-sMMMo yMMMMMMMMMMMMMMMMMMy sMMMs-/dMMMMMMMMd`:MM [INFO] MMm-.hMMMMMMMMMdhMNo`+MMMMMMMMMMMMMMMMMMMM+`oNMhdMMMMMMMMMh.-mMM [INFO] MMMNo./hmNMMMMMNms--yMMMMMMMMMMMMMMMMMMMMMMy--smNMMMMMNmy/.oNMMM [INFO] MMMMMms:-:/+++/:-+hMMMMMMMMMMMMMMMMMMMMMMMMMNh+-:/+++/:-:smMMMMM [INFO] MMMMMMMMNdhhyhdmMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMmdhyhhmNMMMMMMMM [INFO] MMMMMMMMMMMMMMMNNNNNMMMMMMNNNNNNMMMMMMMMNNMMMMMMMNNMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMh/-...-+dMMMm......:+hMMMMs../MMMMMo..sMMMMMMMMMMMM [INFO] MMMMMMMMMMMM/ /yhy- sMMm -hhy/ :NMM+ oMMMy /MMMMMMMMMMMM [INFO] MMMMMMMMMMMy /MMMMN` NMm /MMMMo +MM: .` yMd :MMMMMMMMMMMM
[INFO] MMMMMMMMMMM+ sMMMMM: hMm /MMMMd -MM- /s h.d- -MMMMMMMMMMMM
[INFO] MMMMMMMMMMMs +MMMMM. mMm /MMMMy /MM. +M/ yM: MMMMMMMMMMMM [INFO] MMMMMMMMMMMN- smNm/ +MMm :NNdo .mMMoMM+/yMM/ MMMMMMMMMMMM [INFO] MMMMMMMMMMMMNo- :yMMMm :sNMMM sMMMMMMM+ NMMMMMMMMMMM
[INFO] MMMMMMMMMMMMMMMNmmNMMMMMMMNmmmmNMMMMMMMNNMMMMMMMMMNNMMMMMMMMMMMM
[INFO] ODM app finished - Fri Oct 02 08:35:01 2020
/usr/local/lib/python3.6/dist-packages/sklearn/externals/joblib/externals/cloudpickle/cloudpickle.py:47: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module’s documentation for alternative uses
import imp
Postprocessing: /var/www/data/10df0a56-8960-4a18-ab28-e134bf4079c7
Found point cloud: odm_georeferencing/odm_georeferenced_model.laz
Scanning input
1/1: odm_georeferencing/odm_georeferenced_model.laz
Determined SRS from an input file
Entwine Version: 2.1.0
EPT Version: 1.0.0
Input:
File: odm_georeferencing/odm_georeferenced_model.laz
Total points: 169,689,403
Density estimate (per square unit): 27.3607
Threads: [1, 7]
Output:
Path: entwine_pointcloud/
Data type: laszip
Hierarchy type: json
Sleep count: 2,097,152
Scale: 0.01
Offset: (277206, 3057974, 406)
Metadata:
SRS: EPSG:32614
Bounds: [(275838, 3056840, 342), (278575, 3059108, 469)]
Cube: [(275837, 3056604, -964), (278577, 3059344, 1776)]
Storing dimensions: [
X:int32, Y:int32, Z:int32, Intensity:uint16, ReturnNumber:uint8,
NumberOfReturns:uint8, ScanDirectionFlag:uint8,
EdgeOfFlightLine:uint8, Classification:uint8, ScanAngleRank:float,
UserData:uint8, PointSourceId:uint16, GpsTime:double, Red:uint16,
Green:uint16, Blue:uint16, OriginId:uint32
Build parameters:
Span: 128
Resolution 2D: 128 * 128 = 16,384
Resolution 3D: 128 * 128 * 128 = 2,097,152
Maximum node size: 65,536
Minimum node size: 16,384
Cache size: 64
Adding 0 - odm_georeferencing/odm_georeferenced_model.laz
Pushes complete - joining…
07:00 - 53% - 90,210,304 - 773(701)M/h - 0W - 55R - 323A
07:20 - 55% - 93,822,976 - 767(548)M/h - 129W - 51R - 264A
07:40 - 57% - 97,046,528 - 759(526)M/h - 134W - 33R - 224A
08:00 - 59% - 100,704,256 - 755(687)M/h - 0W - 60R - 329A
08:20 - 61% - 103,849,984 - 747(514)M/h - 123W - 43R - 273A
08:40 - 63% - 106,971,136 - 740(673)M/h - 0W - 51R - 324A
09:00 - 65% - 109,731,840 - 731(464)M/h - 113W - 36R - 248A
09:20 - 67% - 113,078,272 - 726(594)M/h - 0W - 73R - 339A
09:40 - 68% - 115,744,768 - 718(489)M/h - 155W - 34R - 237A
10:00 - 70% - 118,796,288 - 712(437)M/h - 128W - 50R - 314A
10:20 - 72% - 121,925,632 - 707(526)M/h - 145W - 48R - 244A
10:40 - 73% - 124,719,104 - 701(414)M/h - 148W - 40R - 274A
11:00 - 76% - 128,172,032 - 699(703)M/h - 98W - 46R - 241A
11:20 - 77% - 131,022,848 - 693(378)M/h - 104W - 37R - 279A
11:40 - 79% - 134,356,992 - 690(698)M/h - 0W - 59R - 369A
12:00 - 81% - 137,244,672 - 686(433)M/h - 143W - 48R - 284A
12:20 - 83% - 140,206,080 - 682(550)M/h - 25W - 55R - 356A
12:40 - 84% - 142,880,768 - 676(524)M/h - 112W - 53R - 291A
13:00 - 86% - 145,723,392 - 672(493)M/h - 148W - 44R - 288A
13:20 - 88% - 148,914,176 - 670(659)M/h - 0W - 59R - 358A
13:40 - 89% - 151,793,664 - 666(575)M/h - 128W - 41R - 270A
14:00 - 91% - 154,443,776 - 661(384)M/h - 149W - 49R - 329A
14:20 - 93% - 157,097,984 - 657(554)M/h - 0W - 62R - 395A
14:40 - 94% - 159,698,944 - 653(496)M/h - 170W - 48R - 262A
15:00 - 96% - 162,369,536 - 649(377)M/h - 154W - 42R - 290A
15:20 - 97% - 165,269,504 - 646(495)M/h - 76W - 46R - 366A
15:40 - 99% - 168,095,744 - 643(608)M/h - 12W - 69R - 418A
Done 0
Reawakened: 3919
Saving registry…
Saving metadata…
Index completed in 15:58.
Save complete.
Points inserted: 169,689,403
Compressing all.zip
I had similar problems. Maybe you can get a pointer or two from my thread?
Thank you @juju
I will try and let you know the results.
I processed without GCP and found no problems. I think I should do some more testing modifying the GCP file.
Saludos
