Hi, I have been using WebODM Lightning but recently I faced some problems The processing node seems to be offline
- I have unlimited credit ( Balance: Unlimited)
- Cannot set processing node
- Processing node seems to be offline (tried to reconnect but connection refused)
Error message: There are no usable processing nodes.
We tried to reach:
** Lightning (queue: 0)*
Make sure that at least one processing node is reachable and that you have granted the current user sufficient permissions to view the processing node (by going to Administration – Processing Nodes – Select Node – Object Permissions – Add User/Group and check CAN VIEW PROCESSING NODE). If you are bringing a node back online, it will take about 30 seconds for WebODM to recognize it.
