I have several already run projects in Lightning that I’m re-visiting to see if I can get them looking better. I noticed a lot of waviness in the mesh for a school construction project I flew. I read from the forum that a lot of extra area outside of the main area of interest will affect how the mesh looks and buy subsetting the area to only the area of interest the mesh will look better. I tried this on several projects and it worked.
On this one after using the boundary parameter and inputting the geojson boundary file it actually made it so the mesh is blank in most areas.
Here’s the original point cloud as viewed in lightning
and here’s the mesh.
Is this an issue with the lightning viewer only? Has anyone else seen this problem?
Thanks for any input. I’ve seen this issue in the past where the mesh doesn’t display.
UPDATE - I have verified that this is not only a display issue in Lightning. I downloaded the mesh and opened it in CloudCompare and found it to look the same.
