I have just started using WebODM having used the processing by DroneDeploy previously. I still fly using the DroneDeploy app as it is convenient. Overlap is 70% and default settings all around, 50 m altitude (Mavic 2 Pro, 32GB RAM, Ryzen 5950X).
The problem is that even though I select the full set of 139 images, only the top part of the area is actually processed. I have tried a few of the processing options in WebODM but the result is the same. I also tried excluding the farmland (that IS processed) and only include the forest (that isn’t), then I only get a tiny area in the middle of the forest, perhaps 3 images combined.
Any idea what is going on here? Surely it must be easier for the software to figure out a forest with trees than a flat grassed area?
This is what is flown, and what WebODM does with the 139 images: Imgur: The magic of the Internet
