WebODM is not reading GCP file
Greeting! uploaded GCPs text file, selected GCPs containing at least 3 imgs for each GCPs, created GCPs file and saved it as gcp_list in folder where the imagery is. then selected images and set processing parameters. after process is completed, I find in quality report that gcp files is not used. Can’t find out the issue why gcp_list file is not being detected though I followed instructions to create and place the file in folder where the imagery is. Anyone guide please.
gcp_list file contents
+proj=utm +zone=42 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
328495.86 3372813.40 1819.555 4798.40 746.21 100_0035_0138.JPG gp1
328495.86 3372813.40 1819.555 4877.55 1822.02 100_0035_0139.JPG gp1
328495.86 3372813.40 1819.555 3021.64 908.22 100_0035_0153.JPG gp1
328495.86 3372813.40 1819.555 3014.67 3292.52 100_0035_0155.JPG gp1
329809.74 3372241.09 1807.145 1043.92 600.44 100_0038_0249.JPG gcp3
329809.74 3372241.09 1807.145 996.33 1458.22 100_0038_0250.JPG gcp3
329809.74 3372241.09 1807.145 997.62 2351.70 100_0038_0251.JPG gcp3
329809.74 3372241.09 1807.145 4914.89 1051.08 100_0038_0423.JPG gcp3
329809.74 3372241.09 1807.145 4927.72 1903.97 100_0038_0424.JPG gcp3
329390.60 3372245.18 1799.728 333.09 144.81 100_0038_0119.JPG gcp4
329390.60 3372245.18 1799.728 299.07 789.30 100_0038_0120.JPG gcp4
329390.60 3372245.18 1799.728 290.22 1489.27 100_0038_0121.JPG gcp4
330033.59 3371443.12 1817.885 3543.32 239.25 100_0039_0238.JPG gcp5
330033.59 3371443.12 1817.885 3617.47 1067.33 100_0039_0239.JPG gcp5
330033.59 3371443.12 1817.885 3667.68 1952.70 100_0039_0240.JPG gcp5
Welcome, Arif!
Are you certain that the file was named gcp_list.txt and not just gcp_list as you indicated above?
https://docs.opendronemap.org/gcp/#gcp-file-format
named it gcp_list and not gcp_list.txt. if this is the issue then renaming gcp_list as gcp_list.txt will be Ok or I will have create the file afresh?
You won’t have to re-create the file, but you will need to reprocess the data from “Load data”.
Thanks a lot for your prompt support. Stay Blessed! Warm regards
