WebODM in terminal ubunutu failed
webodm failed in terminal under ubuntu
but in super user mode (sudo) that’s ok!
You might beneift by adding your user to the docker group so it inherits the docker group’s permissions.
This should work on your platform:
sudo usermod -aG docker $USER
You can verify it was set with this:
id $USER | grep docker
It should not return empty.
Hi! Saijin,
i write in the terminal:
WebODM failed after ($ cd WebODM and $ ./webodm.sh start)
I suppose USER=francois
so i try : sudo usermod -aG docker $francois
and same error
I don’t try : ```
Sorry again but using terminal with linux is not clear for me :face_with_diagonal_mouth:
Ah, okay.
Try this and post the screenshot of what your terminal looks like:
sudo usermod -aG docker francois
Then, try this and screenshot what your terminal looks like:
id francois | grep docker
yes I try…
You will now need to logout and log back in, or reboot for the group change to take effect.
Perfect! :white_check_mark:
Happy processing!
Please stop by #the-showroom to show everyone what you’re working on!
