WebODM Hung up at completion?
Hi - I am relatively new here and this group has been very helpful. I hope to be able to add value as well…as I learn more and gain more experience.
My latest dilemma - I have two local node runs that were “Running” in WebODM…the log shows the following at the end:
Done 0
Reawakened: 27476
Saving registry…
These were very large / long runs and I’d like not to lose the data if possible. Any thoughts on how to extract the results?..without being an ODM command line expert?
Thanks for any help you can provide!
Check out the docker cp command from docs.docker.com (but you do need to have some familiarity with the command line and docker). There’s no GUI way to extract results if the process got stuck.
