WebODM "Exceeded ...", WebODM lightning will not install
The dreaded “Exceeded …”, notification. removed acronis(unnecessary?), and allowed full access through Microsoft’s Firewall … no luck. I wonder if “Python”, is an issue, since after the crash two to four running “Python” programs use up to 50% & 40% of my computer power … not much left …
A dozen or more attempts since yesterday, but nothing seems to resolve the issue … I’m not UNIX savvy but don’t really want to spend another $60 to do a re-install. This “Exceeded …”, issue has been a no problem issue, until today.
If I were to re-pay for a new install, is it likely that this problem will persist on my Levono Windows 10, 16GB computer with no video accelerator?
John
“Booting WebODM 1.9.3 build 30…”
“Trying to connect to NodeODM localhost:29301…”
“Attempt 0 failed, retrying…”
“Attempt 1 failed, retrying…”
“Attempt 2 failed, retrying…”
“nodeodm: info: Authentication using SimpleToken\r\n”
“nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\n”
“nodeodm: info: Initialized 2 tasks\r\n”
“nodeodm: info: Checking for orphaned directories to be removed…\r\n”
“nodeodm: info: About to run: C:\WebODM\resources\app\apps\ODM\run.bat --ignore-gsd --pc-quality high --dsm --dem-resolution 2 --orthophoto-resolution 2 --pc-ept --cog --project-path C:\WebODM\resources\app\apps\NodeODM\data 509feed8-4f96-4cb3-85a7-4724cd92466f\r\n”
“nodeodm: info: Server has started on port 29301\r\n”
“Connected to NodeODM 2.1.9”
“redis-server: . \n .-__ ''-._ \n _.- . . ‘’-._ Redis 3.2.100 (00000000/0) 64 bit\n .- .-```. ```\\/ _.,_ ''-._ \n ( ' , .-` | `, ) Running in standalone mode\n |`-._`-...-` __...-.-.|’_.-'| Port: 29379\n | -. ._ / _.-' | PID: 9304\n -._ -._ -./ .-’ .-’ \n |-._-. -.__.-' _.-'_.-'| \n | -.-._ _.-'_.-' | http://redis.io \n -._ -._-..-’.-’ .-’ \n |-._-. -.__.-' _.-'_.-'| \n | -.-._ _.-'_.-' | \n -._ -._-..-’_.-’ _.-’ \n -._ -..-’ _.-’ \n -._ _.-' \n -..-’ \n\n[9304] 15 Dec 14:13:53.967 # Server started, Redis version 3.2.100\n”
“redis-server: [9304] 15 Dec 14:13:54.141 * DB loaded from disk: 0.174 seconds\n[9304] 15 Dec 14:13:54.141 * The server is now ready to accept connections on port 29379\n”
“C:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: waiting for server to shut down…”
“C:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: .”
“C:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: done\r\n”
“C:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: server stopped\r\n”
“C:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: exited with code 0”
“Trying to connect to postgres localhost:29543…”
“C:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: server starting\r\n”
“C:\WebODM\resources\app\apps\pgsql/bin/psql: psql: FATAL: the database system is starting up\r\n”
“C:\WebODM\resources\app\apps\pgsql/bin/psql: exited with code 2”
“C:\WebODM\resources\app\apps\pgsql/bin/psql: psql: FATAL: password authentication failed for user “postgres”\r\n”
“C:\WebODM\resources\app\apps\pgsql/bin/psql: exited with code 0”
“python: Operations to perform:\r\n Apply all migrations: admin, app, auth, contenttypes, guardian, nodeodm, sessions\r\nRunning migrations:\r\n No migrations to apply.\r\n”
“python: exited with code 0”
“python: [2022-12-15 14:18:20,192: INFO/MainProcess] Connected to redis://:@127.0.0.1:29379//\r\n"
“python: [2022-12-15 14:18:20,280: INFO/MainProcess] mingle: searching for neighbors\r\n”
“python: [2022-12-15 14:18:21,435: INFO/MainProcess] mingle: all alone\r\n”
“python: [2022-12-15 14:18:21,447: INFO/MainProcess] [email protected] ready.\r\n”
"python: [2022-12-15 14:18:21,466: INFO/MainProcess] pidbox: Connected to redis://:
@127.0.0.1:29379//.\r\n”
“python: [2022-12-15 14:18:24,814: INFO/MainProcess] Received task: worker.tasks.process_task[f8ba5b28-75ff-4729-8c84-8b7cb2cef72e] \r\n”
“python: [2022-12-15 14:18:30,370: INFO/MainProcess] Received task: worker.tasks.process_task[61c946b6-c2ec-4165-9d83-fbc813e4d9fe] \r\n”
“python: [2022-12-15 14:18:30,374: INFO/MainProcess] Task worker.tasks.process_task[61c946b6-c2ec-4165-9d83-fbc813e4d9fe] succeeded in 0.01499999999987267s: None\r\n”
“python: [2022-12-15 14:18:35,587: INFO/MainProcess] Received task: worker.tasks.process_task[f3e88d0d-1c56-41fb-bf57-beba1a512e83] \r\n”
“python: [2022-12-15 14:18:35,591: INFO/MainProcess] Task worker.tasks.process_task[f3e88d0d-1c56-41fb-bf57-beba1a512e83] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:18:39,161: INFO/MainProcess] Received task: worker.tasks.process_task[63263a67-636e-48f2-8a36-55a3f05e56be] \r\n”
“python: [2022-12-15 14:18:39,163: INFO/MainProcess] Task worker.tasks.process_task[63263a67-636e-48f2-8a36-55a3f05e56be] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:18:43,079: INFO/MainProcess] Task worker.tasks.process_task[f8ba5b28-75ff-4729-8c84-8b7cb2cef72e] succeeded in 18.266000000000076s: None\r\n”
“python: [2022-12-15 14:18:43,970: INFO/MainProcess] Received task: worker.tasks.process_task[bb02002f-d329-435d-84ab-47ffdacb43a9] \r\n”
“python: [2022-12-15 14:18:48,786: INFO/MainProcess] Received task: worker.tasks.process_task[d54e96c0-654c-4a34-a60b-37a049f102a4] \r\n”
“python: [2022-12-15 14:18:48,790: INFO/MainProcess] Task worker.tasks.process_task[d54e96c0-654c-4a34-a60b-37a049f102a4] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:18:54,052: INFO/MainProcess] Received task: worker.tasks.process_task[688e91d9-4fef-4610-a9e9-d457ff5c960f] \r\n”
“python: [2022-12-15 14:18:54,057: INFO/MainProcess] Task worker.tasks.process_task[688e91d9-4fef-4610-a9e9-d457ff5c960f] succeeded in 0.0s: None\r\n”
“redis-server: [9304] 15 Dec 14:18:54.085 * 10 changes in 300 seconds. Saving…\n”
“redis-server: [9304] 15 Dec 14:18:54.232 * Background saving started by pid 936\n”
“python: [2022-12-15 14:18:54,968: INFO/MainProcess] Task worker.tasks.process_task[bb02002f-d329-435d-84ab-47ffdacb43a9] succeeded in 11.0s: None\r\n”
“redis-server: [9304] 15 Dec 14:18:56.680 # fork operation complete\n”
“redis-server: [9304] 15 Dec 14:18:56.966 * Background saving terminated with success\n”
“python: [2022-12-15 14:18:59,620: INFO/MainProcess] Received task: worker.tasks.process_task[8762bcde-8eec-4850-bf62-53abb4de4fa8] \r\n”
“python: [2022-12-15 14:19:04,735: INFO/MainProcess] Received task: worker.tasks.process_task[228ccc46-bc8c-4e30-ab21-838fde20109e] \r\n”
“python: [2022-12-15 14:19:04,740: INFO/MainProcess] Task worker.tasks.process_task[228ccc46-bc8c-4e30-ab21-838fde20109e] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:19:08,950: INFO/MainProcess] Received task: worker.tasks.process_task[a1ccc8b9-4d2b-4bc3-9f7d-617b72d8d586] \r\n”
“python: [2022-12-15 14:19:08,955: INFO/MainProcess] Task worker.tasks.process_task[a1ccc8b9-4d2b-4bc3-9f7d-617b72d8d586] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:19:12,879: INFO/MainProcess] Task worker.tasks.process_task[8762bcde-8eec-4850-bf62-53abb4de4fa8] succeeded in 13.264999999999873s: None\r\n”
“python: [2022-12-15 14:19:14,914: INFO/MainProcess] Received task: worker.tasks.process_task[d2e9e90f-00ab-45fb-811d-70e4def48b17] \r\n”
“python: [2022-12-15 14:19:19,843: INFO/MainProcess] Received task: worker.tasks.process_task[9ded050c-aeb0-45bf-8e36-9aa698069055] \r\n”
“python: [2022-12-15 14:19:19,848: INFO/MainProcess] Task worker.tasks.process_task[9ded050c-aeb0-45bf-8e36-9aa698069055] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:19:23,871: INFO/MainProcess] Received task: worker.tasks.process_task[316b46fc-4713-4743-a01b-72cab1dfe899] \r\n”
“python: [2022-12-15 14:19:23,875: INFO/MainProcess] Task worker.tasks.process_task[316b46fc-4713-4743-a01b-72cab1dfe899] succeeded in 0.01499999999987267s: None\r\n”
“python: [2022-12-15 14:19:26,695: INFO/MainProcess] Task worker.tasks.process_task[d2e9e90f-00ab-45fb-811d-70e4def48b17] succeeded in 11.780999999999949s: None\r\n”
“python: [2022-12-15 14:19:28,792: INFO/MainProcess] Received task: worker.tasks.process_task[38f62130-4932-40cc-bceb-21c2773debc5] \r\n”
“python: [2022-12-15 14:19:34,002: INFO/MainProcess] Received task: worker.tasks.process_task[894575b4-8051-4e15-abd0-b2ff8de28570] \r\n”
“python: [2022-12-15 14:19:34,005: INFO/MainProcess] Task worker.tasks.process_task[894575b4-8051-4e15-abd0-b2ff8de28570] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:19:38,783: INFO/MainProcess] Received task: worker.tasks.process_task[185b2d0d-62db-4826-8a98-948d760847bf] \r\n”
“python: [2022-12-15 14:19:38,785: INFO/MainProcess] Task worker.tasks.process_task[185b2d0d-62db-4826-8a98-948d760847bf] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:19:39,850: INFO/MainProcess] Task worker.tasks.process_task[38f62130-4932-40cc-bceb-21c2773debc5] succeeded in 11.061999999999898s: None\r\n”
“python: [2022-12-15 14:19:43,966: INFO/MainProcess] Received task: worker.tasks.process_task[0eabc47a-e898-46d1-9965-a73af6413e98] \r\n”
“python: [2022-12-15 14:19:50,370: INFO/MainProcess] Received task: worker.tasks.process_task[46e7a55e-a82d-4c74-befc-ce89eaf09a6a] \r\n”
“python: [2022-12-15 14:19:50,375: INFO/MainProcess] Task worker.tasks.process_task[46e7a55e-a82d-4c74-befc-ce89eaf09a6a] succeeded in 0.01499999999987267s: None\r\n”
“python: [2022-12-15 14:19:53,542: INFO/MainProcess] Task worker.tasks.process_task[0eabc47a-e898-46d1-9965-a73af6413e98] succeeded in 9.563000000000102s: None\r\n”
“python: [2022-12-15 14:19:54,648: INFO/MainProcess] Received task: worker.tasks.process_task[31d38cec-7758-4c7e-a30b-82ea3ac4f3e3] \r\n”
“python: [2022-12-15 14:19:59,700: INFO/MainProcess] Received task: worker.tasks.process_task[cd81ac2e-8bbd-48cf-a272-5660255474ca] \r\n”
“python: [2022-12-15 14:19:59,705: INFO/MainProcess] Task worker.tasks.process_task[cd81ac2e-8bbd-48cf-a272-5660255474ca] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:03,871: INFO/MainProcess] Received task: worker.tasks.process_task[6aa34b6c-fe6b-4668-86b1-6b3adabb1b81] \r\n”
“python: [2022-12-15 14:20:03,873: INFO/MainProcess] Task worker.tasks.process_task[6aa34b6c-fe6b-4668-86b1-6b3adabb1b81] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:06,362: INFO/MainProcess] Task worker.tasks.process_task[31d38cec-7758-4c7e-a30b-82ea3ac4f3e3] succeeded in 11.719000000000051s: None\r\n”
“python: [2022-12-15 14:20:08,749: INFO/MainProcess] Received task: worker.tasks.process_task[3df43da7-cf13-4451-98b2-465acf392d92] \r\n”
“python: [2022-12-15 14:20:15,000: INFO/MainProcess] Received task: worker.tasks.process_task[16dd3759-002e-42c9-a4ee-c75917b97357] \r\n”
“python: [2022-12-15 14:20:15,004: INFO/MainProcess] Task worker.tasks.process_task[16dd3759-002e-42c9-a4ee-c75917b97357] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:18,886: INFO/MainProcess] Received task: worker.tasks.process_task[8ba1f956-0b26-4231-9e21-a82394985d0a] \r\n”
“python: [2022-12-15 14:20:18,891: INFO/MainProcess] Task worker.tasks.process_task[8ba1f956-0b26-4231-9e21-a82394985d0a] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:19,868: INFO/MainProcess] Task worker.tasks.process_task[3df43da7-cf13-4451-98b2-465acf392d92] succeeded in 11.110000000000127s: None\r\n”
“python: [2022-12-15 14:20:23,878: INFO/MainProcess] Received task: worker.tasks.process_task[2b9b6e50-4df4-4087-ae9a-be5c5db9e811] \r\n”
“python: [2022-12-15 14:20:28,737: INFO/MainProcess] Received task: worker.tasks.process_task[a3fb02ac-70c3-4a98-850d-fe4f97bf1df7] \r\n”
“python: [2022-12-15 14:20:28,741: INFO/MainProcess] Task worker.tasks.process_task[a3fb02ac-70c3-4a98-850d-fe4f97bf1df7] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:35,162: INFO/MainProcess] Received task: worker.tasks.process_task[45355515-59cf-492b-94d5-a681b2d9cb1e] \r\n”
“python: [2022-12-15 14:20:35,166: INFO/MainProcess] Task worker.tasks.process_task[45355515-59cf-492b-94d5-a681b2d9cb1e] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:38,790: INFO/MainProcess] Task worker.tasks.process_task[2b9b6e50-4df4-4087-ae9a-be5c5db9e811] succeeded in 14.907000000000153s: None\r\n”
“python: [2022-12-15 14:20:39,782: INFO/MainProcess] Received task: worker.tasks.process_task[a971f85d-6b23-47ae-ac22-6be8a2e047e6] \r\n”
“python: [2022-12-15 14:20:46,116: INFO/MainProcess] Received task: worker.tasks.process_task[4b96af88-225b-46f8-b8fa-bc67d602f0ed] \r\n”
“python: [2022-12-15 14:20:46,121: INFO/MainProcess] Task worker.tasks.process_task[4b96af88-225b-46f8-b8fa-bc67d602f0ed] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:50,413: INFO/MainProcess] Received task: worker.tasks.process_task[2c113863-2ffa-456d-8b6d-9b959955a86e] \r\n”
“python: [2022-12-15 14:20:50,416: INFO/MainProcess] Task worker.tasks.process_task[2c113863-2ffa-456d-8b6d-9b959955a86e] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:53,780: INFO/MainProcess] Received task: worker.tasks.process_task[290a53fc-c4c2-402c-b8cc-7b7c5a3f165f] \r\n”
“python: [2022-12-15 14:20:53,784: INFO/MainProcess] Task worker.tasks.process_task[290a53fc-c4c2-402c-b8cc-7b7c5a3f165f] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:20:55,805: INFO/MainProcess] Task worker.tasks.process_task[a971f85d-6b23-47ae-ac22-6be8a2e047e6] succeeded in 16.014999999999873s: None\r\n”
“python: [2022-12-15 14:20:59,267: INFO/MainProcess] Received task: worker.tasks.process_task[530a2407-954e-428d-9169-1f0f47473d97] \r\n”
“python: [2022-12-15 14:21:03,743: INFO/MainProcess] Received task: worker.tasks.process_task[99412965-f381-455e-97b9-bab6870fabb0] \r\n”
“python: [2022-12-15 14:21:03,747: INFO/MainProcess] Task worker.tasks.process_task[99412965-f381-455e-97b9-bab6870fabb0] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:21:09,634: INFO/MainProcess] Received task: worker.tasks.process_task[1b7c2885-e551-47f1-ba89-0422e7416884] \r\n”
“python: [2022-12-15 14:21:09,638: INFO/MainProcess] Task worker.tasks.process_task[1b7c2885-e551-47f1-ba89-0422e7416884] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:21:10,153: INFO/MainProcess] Task worker.tasks.process_task[530a2407-954e-428d-9169-1f0f47473d97] succeeded in 10.875s: None\r\n”
“python: [2022-12-15 14:21:14,973: INFO/MainProcess] Received task: worker.tasks.process_task[1b37ef32-d545-4a6f-b479-265f79122a5a] \r\n”
“python: [2022-12-15 14:21:19,870: INFO/MainProcess] Received task: worker.tasks.process_task[89aaa062-3965-4e2a-b6da-50baff7a4c9f] \r\n”
“python: [2022-12-15 14:21:19,875: INFO/MainProcess] Task worker.tasks.process_task[89aaa062-3965-4e2a-b6da-50baff7a4c9f] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:21:24,325: INFO/MainProcess] Received task: worker.tasks.process_task[b061713b-6c8d-4f9c-9141-88f80f346939] \r\n”
“python: [2022-12-15 14:21:24,331: INFO/MainProcess] Task worker.tasks.process_task[b061713b-6c8d-4f9c-9141-88f80f346939] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:21:27,701: INFO/MainProcess] Task worker.tasks.process_task[1b37ef32-d545-4a6f-b479-265f79122a5a] succeeded in 12.719000000000051s: None\r\n”
“python: [2022-12-15 14:21:29,110: INFO/MainProcess] Received task: worker.tasks.process_task[770ec6fd-5224-488e-b75d-2658bc9d4bb5] \r\n”
“python: [2022-12-15 14:21:34,030: INFO/MainProcess] Received task: worker.tasks.process_task[28d1b3fc-8b08-47e7-ba72-db5c2a8e2583] \r\n”
“python: [2022-12-15 14:21:34,035: INFO/MainProcess] Task worker.tasks.process_task[28d1b3fc-8b08-47e7-ba72-db5c2a8e2583] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:21:39,121: INFO/MainProcess] Received task: worker.tasks.process_task[31080269-3ad9-4286-aec7-44769056d63e] \r\n”
“python: [2022-12-15 14:21:39,127: INFO/MainProcess] Task worker.tasks.process_task[31080269-3ad9-4286-aec7-44769056d63e] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:21:40,817: INFO/MainProcess] Task worker.tasks.process_task[770ec6fd-5224-488e-b75d-2658bc9d4bb5] succeeded in 11.702999999999975s: None\r\n”
“python: [2022-12-15 14:21:45,870: INFO/MainProcess] Received task: worker.tasks.process_task[7e3f0b89-fc6f-4332-a7c7-c5a8ff545ede] \r\n”
“python: [2022-12-15 14:21:49,808: INFO/MainProcess] Received task: worker.tasks.process_task[9e1a9539-949b-4c69-bf27-b0af37ce0a90] \r\n”
“python: [2022-12-15 14:21:49,815: INFO/MainProcess] Task worker.tasks.process_task[9e1a9539-949b-4c69-bf27-b0af37ce0a90] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:21:54,458: INFO/MainProcess] Received task: worker.tasks.process_task[43c9404c-a8d2-409c-b691-39868c7e876c] \r\n”
“python: [2022-12-15 14:21:54,464: INFO/MainProcess] Task worker.tasks.process_task[43c9404c-a8d2-409c-b691-39868c7e876c] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:21:59,439: INFO/MainProcess] Received task: worker.tasks.process_task[2918655b-1fc2-45bd-a471-b487cccefd6b] \r\n”
“python: [2022-12-15 14:21:59,446: INFO/MainProcess] Task worker.tasks.process_task[2918655b-1fc2-45bd-a471-b487cccefd6b] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:22:02,653: INFO/MainProcess] Task worker.tasks.process_task[7e3f0b89-fc6f-4332-a7c7-c5a8ff545ede] succeeded in 16.78099999999995s: None\r\n”
“python: [2022-12-15 14:22:04,248: INFO/MainProcess] Received task: worker.tasks.process_task[9b2cbab1-be47-4fb3-b7a3-34832a88f775] \r\n”
“python: [2022-12-15 14:22:10,083: INFO/MainProcess] Received task: worker.tasks.process_task[8cf9ae05-d059-419d-95ef-112be75e7d32] \r\n”
“python: [2022-12-15 14:22:10,091: INFO/MainProcess] Task worker.tasks.process_task[8cf9ae05-d059-419d-95ef-112be75e7d32] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:22:15,730: INFO/MainProcess] Received task: worker.tasks.process_task[679006f6-1136-4a32-9c0f-baf40e32057f] \r\n”
“python: [2022-12-15 14:22:15,735: INFO/MainProcess] Task worker.tasks.process_task[679006f6-1136-4a32-9c0f-baf40e32057f] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:22:19,620: INFO/MainProcess] Received task: worker.tasks.process_task[a40f3d25-8a9b-49dd-ade6-3067a279b2fd] \r\n”
“python: [2022-12-15 14:22:19,623: INFO/MainProcess] Task worker.tasks.process_task[a40f3d25-8a9b-49dd-ade6-3067a279b2fd] succeeded in 0.01499999999987267s: None\r\n”
“python: [2022-12-15 14:22:21,201: INFO/MainProcess] Task worker.tasks.process_task[9b2cbab1-be47-4fb3-b7a3-34832a88f775] succeeded in 16.95400000000018s: None\r\n”
“python: [2022-12-15 14:22:24,558: INFO/MainProcess] Received task: worker.tasks.process_task[39a78d41-6295-4beb-a55f-f5426df5b256] \r\n”
“python: [2022-12-15 14:22:29,139: INFO/MainProcess] Received task: worker.tasks.process_task[99db5957-be43-4a19-ae32-2979c40490b6] \r\n”
“python: [2022-12-15 14:22:29,143: INFO/MainProcess] Task worker.tasks.process_task[99db5957-be43-4a19-ae32-2979c40490b6] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:22:34,145: INFO/MainProcess] Received task: worker.tasks.process_task[4aae6d03-d428-4219-8ff2-721e792f0990] \r\n”
“python: [2022-12-15 14:22:34,149: INFO/MainProcess] Task worker.tasks.process_task[4aae6d03-d428-4219-8ff2-721e792f0990] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:22:35,789: INFO/MainProcess] Task worker.tasks.process_task[39a78d41-6295-4beb-a55f-f5426df5b256] succeeded in 11.235000000000127s: None\r\n”
“python: [2022-12-15 14:22:39,172: INFO/MainProcess] Received task: worker.tasks.process_task[adcf03ef-b809-457c-9201-f720b8df2ae9] \r\n”
“python: [2022-12-15 14:22:44,189: INFO/MainProcess] Received task: worker.tasks.process_task[d275b223-1c2d-4e1f-806b-04e624caf7cd] \r\n”
“python: [2022-12-15 14:22:44,194: INFO/MainProcess] Task worker.tasks.process_task[d275b223-1c2d-4e1f-806b-04e624caf7cd] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:22:49,342: INFO/MainProcess] Received task: worker.tasks.process_task[170da265-d74f-4eb4-ba53-159bc1ffb3d8] \r\n”
“python: [2022-12-15 14:22:49,347: INFO/MainProcess] Task worker.tasks.process_task[170da265-d74f-4eb4-ba53-159bc1ffb3d8] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:22:51,214: INFO/MainProcess] Task worker.tasks.process_task[adcf03ef-b809-457c-9201-f720b8df2ae9] succeeded in 12.032000000000153s: None\r\n”
“python: [2022-12-15 14:22:54,172: INFO/MainProcess] Received task: worker.tasks.process_task[0c36f2af-8d26-4db6-9a1a-3bc42b1c7e90] \r\n”
“python: [2022-12-15 14:23:00,840: INFO/MainProcess] Received task: worker.tasks.process_task[2a134186-dc44-48c6-9e4b-7112402c024f] \r\n”
“python: [2022-12-15 14:23:00,846: INFO/MainProcess] Task worker.tasks.process_task[2a134186-dc44-48c6-9e4b-7112402c024f] succeeded in 0.01499999999987267s: None\r\n”
“python: [2022-12-15 14:23:04,193: INFO/MainProcess] Received task: worker.tasks.process_task[077d489b-0752-48cd-b1fe-85f82c9c3430] \r\n”
“python: [2022-12-15 14:23:04,197: INFO/MainProcess] Task worker.tasks.process_task[077d489b-0752-48cd-b1fe-85f82c9c3430] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:23:06,735: INFO/MainProcess] Task worker.tasks.process_task[0c36f2af-8d26-4db6-9a1a-3bc42b1c7e90] succeeded in 12.563000000000102s: None\r\n”
“python: [2022-12-15 14:23:09,827: INFO/MainProcess] Received task: worker.tasks.process_task[66e8109d-beff-4162-a190-28fa850e8a8d] \r\n”
“python: [2022-12-15 14:23:14,080: INFO/MainProcess] Received task: worker.tasks.process_task[7187f398-db39-494b-911b-d3bf2cab905c] \r\n”
“python: [2022-12-15 14:23:14,086: INFO/MainProcess] Task worker.tasks.process_task[7187f398-db39-494b-911b-d3bf2cab905c] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:23:19,014: INFO/MainProcess] Task worker.tasks.process_task[66e8109d-beff-4162-a190-28fa850e8a8d] succeeded in 9.186999999999898s: None\r\n”
“python: [2022-12-15 14:23:19,093: INFO/MainProcess] Received task: worker.tasks.process_task[3c1c628a-3b01-4eca-bdeb-89979624723a] \r\n”
“python: [2022-12-15 14:23:25,610: INFO/MainProcess] Received task: worker.tasks.process_task[291c2561-cea5-41d5-bf4b-596a90a72990] \r\n”
“python: [2022-12-15 14:23:25,613: INFO/MainProcess] Task worker.tasks.process_task[291c2561-cea5-41d5-bf4b-596a90a72990] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:23:29,164: INFO/MainProcess] Received task: worker.tasks.process_task[124cc4d7-6ffe-4d62-bdb3-a9a60d1d0c2d] \r\n”
“python: [2022-12-15 14:23:29,167: INFO/MainProcess] Task worker.tasks.process_task[124cc4d7-6ffe-4d62-bdb3-a9a60d1d0c2d] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:23:29,500: INFO/MainProcess] Task worker.tasks.process_task[3c1c628a-3b01-4eca-bdeb-89979624723a] succeeded in 10.405999999999949s: None\r\n”
“python: [2022-12-15 14:23:34,206: INFO/MainProcess] Received task: worker.tasks.process_task[f6cb98f7-fd27-40e1-83da-6898c1e4cbbb] \r\n”
“python: [2022-12-15 14:23:39,315: INFO/MainProcess] Received task: worker.tasks.process_task[951711d9-eb6c-41cc-8e00-420c2379cf2c] \r\n”
“python: [2022-12-15 14:23:39,318: INFO/MainProcess] Task worker.tasks.process_task[951711d9-eb6c-41cc-8e00-420c2379cf2c] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:23:44,777: INFO/MainProcess] Received task: worker.tasks.process_task[ebc6653a-ddac-4953-b869-4e273230ed5f] \r\n”
“python: [2022-12-15 14:23:44,780: INFO/MainProcess] Task worker.tasks.process_task[ebc6653a-ddac-4953-b869-4e273230ed5f] succeeded in 0.016000000000076398s: None\r\n”
“python: [2022-12-15 14:23:45,935: INFO/MainProcess] Task worker.tasks.process_task[f6cb98f7-fd27-40e1-83da-6898c1e4cbbb] succeeded in 11.717999999999847s: None\r\n”
“python: [2022-12-15 14:23:49,286: INFO/MainProcess] Received task: worker.tasks.process_task[9fc86c23-b0a8-4f6c-a234-1bf2d6b46fad] \r\n”
“python: [2022-12-15 14:23:54,882: INFO/MainProcess] Received task: worker.tasks.process_task[246d194c-6c49-492a-89cd-8d2487c31fb2] \r\n”
“python: [2022-12-15 14:23:54,885: INFO/MainProcess] Task worker.tasks.process_task[246d194c-6c49-492a-89cd-8d2487c31fb2] succeeded in 0.0s: None\r\n”
“redis-server: [9304] 15 Dec 14:23:57.140 * 10 changes in 300 seconds. Saving…\n”
“redis-server: [9304] 15 Dec 14:23:57.239 * Background saving started by pid 9688\n”
“python: [2022-12-15 14:23:58,882: INFO/MainProcess] Task worker.tasks.process_task[9fc86c23-b0a8-4f6c-a234-1bf2d6b46fad] succeeded in 9.592999999999847s: None\r\n”
“redis-server: [9304] 15 Dec 14:23:59.729 # fork operation complete\n”
“redis-server: [9304] 15 Dec 14:24:00.052 * Background saving terminated with success\n”
“python: [2022-12-15 14:24:03,451: INFO/MainProcess] Received task: worker.tasks.process_task[f206b9e2-8879-4166-82e4-84ce6294f370] \r\n”
“python: [2022-12-15 14:24:05,332: INFO/MainProcess] Received task: worker.tasks.process_task[16549228-cbc5-4e5f-a04a-d2250687ae8d] \r\n”
“python: [2022-12-15 14:24:05,336: INFO/MainProcess] Task worker.tasks.process_task[16549228-cbc5-4e5f-a04a-d2250687ae8d] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:24:09,472: INFO/MainProcess] Received task: worker.tasks.process_task[385dbdd3-d52d-45fe-bfc3-a694d5d9f4c9] \r\n”
“python: [2022-12-15 14:24:09,475: INFO/MainProcess] Task worker.tasks.process_task[385dbdd3-d52d-45fe-bfc3-a694d5d9f4c9] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:24:13,102: INFO/MainProcess] Task worker.tasks.process_task[f206b9e2-8879-4166-82e4-84ce6294f370] succeeded in 9.639999999999873s: None\r\n”
“python: [2022-12-15 14:24:14,711: INFO/MainProcess] Received task: worker.tasks.process_task[107556aa-de57-4ffd-abc2-70422a2f5f57] \r\n”
“python: [2022-12-15 14:24:19,514: INFO/MainProcess] Received task: worker.tasks.process_task[8fd808e5-6d7f-422e-bf2c-82610a0b0876] \r\n”
“python: [2022-12-15 14:24:19,517: INFO/MainProcess] Task worker.tasks.process_task[8fd808e5-6d7f-422e-bf2c-82610a0b0876] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:24:25,018: INFO/MainProcess] Task worker.tasks.process_task[107556aa-de57-4ffd-abc2-70422a2f5f57] succeeded in 10.311999999999898s: None\r\n”
“python: [2022-12-15 14:24:25,328: INFO/MainProcess] Received task: worker.tasks.process_task[9df6bf07-8c1e-4f85-9a30-cf69cbb6cc0d] \r\n”
“python: [2022-12-15 14:24:29,467: INFO/MainProcess] Received task: worker.tasks.process_task[3c62dcd0-7a36-431e-8e68-e9772b6058ca] \r\n”
“python: [2022-12-15 14:24:29,470: INFO/MainProcess] Task worker.tasks.process_task[3c62dcd0-7a36-431e-8e68-e9772b6058ca] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:24:35,334: INFO/MainProcess] Received task: worker.tasks.process_task[c8d6882a-14c3-49a7-aac2-4105a9198ac4] \r\n”
“python: [2022-12-15 14:24:35,337: INFO/MainProcess] Task worker.tasks.process_task[c8d6882a-14c3-49a7-aac2-4105a9198ac4] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:24:37,338: INFO/MainProcess] Task worker.tasks.process_task[9df6bf07-8c1e-4f85-9a30-cf69cbb6cc0d] succeeded in 12.0s: None\r\n”
“python: [2022-12-15 14:24:39,617: INFO/MainProcess] Received task: worker.tasks.process_task[fd905653-49dc-4373-82a7-f1ceea6646a1] \r\n”
“python: [2022-12-15 14:24:45,838: INFO/MainProcess] Received task: worker.tasks.process_task[4dc078da-a7d9-4a16-b02c-67c8cd7e9093] \r\n”
“python: [2022-12-15 14:24:45,841: INFO/MainProcess] Task worker.tasks.process_task[4dc078da-a7d9-4a16-b02c-67c8cd7e9093] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:24:49,886: INFO/MainProcess] Received task: worker.tasks.process_task[37388170-eed4-45e0-ab54-15b33f5f658b] \r\n”
“python: [2022-12-15 14:24:49,890: INFO/MainProcess] Task worker.tasks.process_task[37388170-eed4-45e0-ab54-15b33f5f658b] succeeded in 0.016000000000076398s: None\r\n”
“python: [2022-12-15 14:24:50,729: INFO/MainProcess] Task worker.tasks.process_task[fd905653-49dc-4373-82a7-f1ceea6646a1] succeeded in 11.108999999999924s: None\r\n”
“python: [2022-12-15 14:24:55,259: INFO/MainProcess] Received task: worker.tasks.process_task[f46ed695-40b9-4ae4-ba4b-da1034526ba6] \r\n”
“python: [2022-12-15 14:25:00,933: INFO/MainProcess] Received task: worker.tasks.process_task[48b2ce8e-2a07-47a0-a484-0e161766af9b] \r\n”
“python: [2022-12-15 14:25:00,939: INFO/MainProcess] Task worker.tasks.process_task[48b2ce8e-2a07-47a0-a484-0e161766af9b] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:25:05,141: INFO/MainProcess] Received task: worker.tasks.process_task[56a92d1a-53fb-45b9-9b64-61ae3eb8b7f5] \r\n”
“python: [2022-12-15 14:25:05,145: INFO/MainProcess] Task worker.tasks.process_task[56a92d1a-53fb-45b9-9b64-61ae3eb8b7f5] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:25:07,877: INFO/MainProcess] Task worker.tasks.process_task[f46ed695-40b9-4ae4-ba4b-da1034526ba6] succeeded in 12.625s: None\r\n”
“python: [2022-12-15 14:25:09,368: INFO/MainProcess] Received task: worker.tasks.process_task[6a3d8611-ea4e-4276-878f-a5fb5287e3f8] \r\n”
“python: [2022-12-15 14:25:15,354: INFO/MainProcess] Received task: worker.tasks.process_task[1c29f7da-f3c0-455f-a6cf-fbd7eab2913a] \r\n”
“python: [2022-12-15 14:25:15,360: INFO/MainProcess] Task worker.tasks.process_task[1c29f7da-f3c0-455f-a6cf-fbd7eab2913a] succeeded in 0.016000000000076398s: None\r\n”
“python: [2022-12-15 14:25:20,328: INFO/MainProcess] Task worker.tasks.process_task[6a3d8611-ea4e-4276-878f-a5fb5287e3f8] succeeded in 10.969000000000051s: None\r\n”
“python: [2022-12-15 14:25:21,077: INFO/MainProcess] Received task: worker.tasks.process_task[5e9603a2-3ccf-4bcb-a4c9-0912e03df1c1] \r\n”
“python: [2022-12-15 14:25:24,235: INFO/MainProcess] Received task: worker.tasks.process_task[6f201fdc-adc4-4040-98bf-a4c7d572faaf] \r\n”
“python: [2022-12-15 14:25:24,239: INFO/MainProcess] Task worker.tasks.process_task[6f201fdc-adc4-4040-98bf-a4c7d572faaf] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:25:30,522: INFO/MainProcess] Received task: worker.tasks.process_task[0f4ba4ca-7bbd-4a52-ae1a-28af7cc5d24c] \r\n”
“python: [2022-12-15 14:25:30,525: INFO/MainProcess] Task worker.tasks.process_task[0f4ba4ca-7bbd-4a52-ae1a-28af7cc5d24c] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:25:32,294: INFO/MainProcess] Task worker.tasks.process_task[5e9603a2-3ccf-4bcb-a4c9-0912e03df1c1] succeeded in 11.202999999999975s: None\r\n”
“python: [2022-12-15 14:25:34,490: INFO/MainProcess] Received task: worker.tasks.process_task[5e88144d-858c-4745-bf41-4a65311f3ed7] \r\n”
“python: [2022-12-15 14:25:39,586: INFO/MainProcess] Received task: worker.tasks.process_task[9eae8a83-1460-4b4b-98e1-8a3926b97ef5] \r\n”
“python: [2022-12-15 14:25:39,590: INFO/MainProcess] Task worker.tasks.process_task[9eae8a83-1460-4b4b-98e1-8a3926b97ef5] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:25:44,887: INFO/MainProcess] Task worker.tasks.process_task[5e88144d-858c-4745-bf41-4a65311f3ed7] succeeded in 10.389999999999873s: None\r\n”
“python: [2022-12-15 14:25:45,201: INFO/MainProcess] Received task: worker.tasks.process_task[3c15e0a2-b3b9-4ee4-a521-559f4a60c2cf] \r\n”
“python: [2022-12-15 14:25:50,132: INFO/MainProcess] Received task: worker.tasks.process_task[6b7eebb9-2f02-4864-b7da-b7b6fa700e68] \r\n”
“python: [2022-12-15 14:25:50,135: INFO/MainProcess] Task worker.tasks.process_task[6b7eebb9-2f02-4864-b7da-b7b6fa700e68] succeeded in 0.0s: None\r\n”
“python: [2022-12-15 14:25:55,152: INFO/MainProcess] Received task: worker.tasks.process_task[5c142641-cd77-440a-b78b-479783e2a983] \r\n”
“python: [2022-12-15 14:25:55,156: INFO/MainProcess] Task worker.tasks.process_task[5c142641-cd77-440a-b78b-479783e2a983] succeeded in 0.016000000000076398s: None\r\n”
“python: [2022-12-15 14:25:55,619: INFO/MainProcess] Task worker.tasks.process_task[3c15e0a2-b3b9-4ee4-a521-559f4a60c2cf] succeeded in 10.422000000000025s: None\r\n”
No need to rebuy.
Reboot, then update. Your version is very out of date.
oh for the venting of an old man …
Attempted to remove WebODM, but computer says it doesn’t exist(though it’s exactly where it should be. Instead, I removed WebODM Lightning and son-of-a-gun, suddenly, WebODM is running just fine again.
So, I checked for updates on the base page(%[email protected]#^%$^ forgot the name of the page … the Hub?), and it gave me the option to download the latest version.
I never chose to Unix, back in the late 80’s cause all my business software ran on DOS or early windows … I find it very hard, almost impossible to learn a whole new way of doing things.
ANYWAYs, I feel very lost since I see no direct relationship of the WebODM, downloaded files, to the files that exist in my C:WebODM files. Looks like Apples & Oranges to me.
So, now I again have a functioning WebODM(though very old), don’t see how to upgrade, and I don’t want to remove a program that is again running.
I’m intrigued with WebODM Lightning, but it did not install properly.
I think I could be happy to use the old WebODM to check my work, and use WebODM Lightning for final computations …
So, this leaves me ONLY wanting to install WebODM Lightning. Is there a trick I’m missing in my attempt to download and install from the website?
My apologies …
No worries!
You can install both side-by-side perfectly fine, but you can not have both running at the same time, as they both collide on the ports they’re using to communicate with sub-components.
And given that you said you have a few python3 processes running (which you shouldn’t if not Tasks are currently processing), that indicates that you’ve had some crashes and parts of WebODM are still up (hence why I suggested a reboot).
So the WebODM Lightning installer you can get from here:
https://webodm.net/static/downloads/WebODM_Setup.exe
The WebODM for Windows native installer you download from your purchase receipts using a special link with your order number (MYSXXXXXX-XXXX-XXXXX). If you don’t have this link, please reach out to [email protected] and I’ll re-send all you need.
WebODM is a good program … rather great for what it does …
But at $60, I’ll bite myself and might just fire up my backup computer and make a rare intelligent decision to dedicate that computer, only for Photogrammetry and for WebODM and WebODM Lightning… best of both worlds, if I can get it done …
Thankyou
John
