WebODM error returned child 139
From @silverefendy on Mon Mar 26 2018 02:03:35 GMT+0000 (UTC)
Help me, i got this error. When first attempt on merging all the image got no error.
With --min-num-features:18000
But the result got cut a little where i need to see it.
So trying to raising the --min-num-features to 24000
After that got this result.
Btw already merging 2 datasets around same quantity.
[INFO] Running georeferencing with OpenSfM transformation matrix
[DEBUG] running /code/build/bin/odm_georef -bundle
File /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/opensfm/bundle_r000.out -inputTransform
File /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/opensfm/geocoords_transformation.txt -input
File /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/odm_texturing_25d/odm_textured_model.obj -output
File /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/odm_texturing_25d/odm_textured_model_geo.obj -inputPointCloud
File /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/opensfm/reconstruction.ply -outputPointCloud
File /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/odm_25dgeoreferencing/odm_georeferenced_model.ply -log
File /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/odm_25dgeoreferencing/odm_georeferencing_log.txt -outputTransform
File /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/odm_25dgeoreferencing/odm_georeferencing_transform.txt -georef
FileOutputPath /var/www/data/ad0c3cf9-2a83-4048-8987-8953a1732b94/odm_25dgeoreferencing/odm_georeferencing_model_geo.txt
[DEBUG] running /code/SuperBuild/build/pdal/bin/pdal pipeline -i /var/www/data/ad0c3cf9-2a83-4048-8987-
8953a1732b94/odm_georeferencing/las.json --readers.ply.filename=/var/www/data/ad0c3cf9-2a83-4048-8987-
8953a1732b94/odm_georeferencing/odm_georeferenced_model.ply --writers.las.filename=/var/www/data/ad0c3cf9-2a83-4048-8987-
8953a1732b94/odm_georeferencing/odm_georeferenced_model.las
Segmentation fault (core dumped)
Traceback (most recent call
last):
plasm.execute(niter=1)
File “/code/scripts/odm_georeferencing.py”, line 142, in process
tree.odm_georeferencing_las_json)
File “/code/opendm/types.py”, line 264, in convert_to_las
‘–writers.las.filename={f_out}’.format(**kwargs))
File “/code/opendm/system.py”, line 34, in run
Exception: Child returned 139
Got arount 700++ photo
ram 16GB and swap 32GB
Link to data set:
https://drive.google.com/open?id=1oOkYL5bBBncxEYTlLW_N3-cbTQYJSNO_
And thanks for this awesome software.
Copied from original issue: https://github.com/OpenDroneMap/OpenDroneMap/issues/792
From @dakotabenjamin on Mon Mar 26 2018 13:52:00 GMT+0000 (UTC)
The link leads to a 404 :cry:
From @silverefendy on Mon Mar 26 2018 14:51:03 GMT+0000 (UTC)
Sorry, already make it on again.
Can google drive make it off by default?
I’m sorry but can i have your email.
I don’t know why,but sometimes i get error 404 if not sign in from my google.
From @dakotabenjamin on Tue Mar 27 2018 17:00:57 GMT+0000 (UTC)
I’ve got it now, thanks
From @silverefendy on Wed Mar 28 2018 02:16:46 GMT+0000 (UTC)
No, i thank you
