WebODM does not work after installing virtualbox
Hi, I’m not sure if it’s the cause. But after installing virtualbox in Ubuntu natively, based on the community script, the installation that was running Webodm has stopped working.
It indicates a problem with docker that I am not able to solve.
What could have happened?. Thank you very much for the help
[email protected]:~/WebODM$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Checking for python… OK
Checking for pip… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up
ERROR: Couldn’t connect to Docker daemon at http+docker://localhost - is it running?
If it’s at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
