WebODM does not start
When I try to start WebODM the following message appears
Choosing yes or no does not solves the problem. The program just restarts and the same message appears.
What can I do?
Thank you.
Hey @rogerio53 :hand:
Can you post a copy of the text from the console tab?
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Initializing console…
OpenSSH check passed
default not found Error open C:\Users\roger.docker\machine\machines\default\config.json: The system cannot find the file specified.
looks like something got corrupted. Could you open Notepad, then press “File” --> “Save”, and save a file named “config.json” in C:\Users\roger.docker\machine\machines\default\ (sometimes notepad appends the .txt extension, make sure that the extension is .json)?
Then try to restart WebODM Manager.
If you still get the error, further try to press the “Open Shell” button from the “Maintenance” panel of WebODM Manager and type:
docker-machine rm -f default
Followed by enter. Then close the shell window, and restart WebODM Manager.
