WebODM: Could not get current device IDinitialization error
I cannot upload my images due to being on a cell hotspot.
I have been using WebODM for about 3 years with few issues I couldn’t figure out, but I recently upgraded to a more powerful machine, and now WebODM is experiencing errors in processing.
My old machine was a Dell tower with a Core i7 processor (8cores), 32GB RAM, and Windows 10 running the windows native install of WebODM. I was able to easily process datasets of 350 pictures or less well enough for my purposes (making orthos with DSM + DTM for design clients)
The new machine is a Dell Precision 7810 tower with dual Xeon processors (24 cores), 128GB RAM, and Windows 10. Running the windows native WebODM. all drives are SSD.
I was getting the “Child Process Returned:1” error, and checking the forums here saw to try updating WebODM, which I have just done. Now running 1.9.11 build 49
When i try to reload a dataset of 186 images flown at 280’ with a double-grid pattern, i now get this error:
[INFO] Photo dimensions for feature extraction: 1000px
d:\a\odm\odm\superbuild\build\pypopsift_deps\popsift-src\src\popsift\sift_conf.cu:47
I have never seen this error before. I checked github and found nothing there. Any help appreciated.
Thanks,
Sam
Seems like the GPU code is unable to get initialized.
You can either disable the GPU by setting a ODM_NO_GPU environment variable system-wide, or perhaps try updating your graphics card driver?
I have updated the driver, but am getting the same error.
If i hit resume processing after this error it runs and creates an Ortho + DSM and DTM, but when I go to view the 3D model it shows nothing. When I select Show Textured Model I get a loading screen and still nothing.
Graphics card is NVIDIA NVS 315
I think your card uses too old a CUDA/Compute version (2.1). It looks like with the R390 driver, it only supports up to CUDA 9.1, and we’re compiled against CUDA 11.4 last I checked.
6 posts were split to a new topic: Trouble with IDInitialization error
This is going to get fixed as soon as Fixes by pierotofy · Pull Request #1402 · OpenDroneMap/ODM · GitHub is merged. :pray:
