I would like to report that orthophoto could not be displayed on the WebODM map if I use NodeODM to process the images. The process end successfully and all the assets were available. Had no problem with 3D model view as well.
No such problem happen if I run the process on local WebODM. Is this a known issue or bug?
I use Caliterra sample images for this test.
