Webodm can't start, tryignto figure out why
I will start by saying that i t was working at one point I was able to make a few renders of maps. I think … 3 in total.
now I am stuck trying to get it open again. I might have done some thing bad by "resetting " or “removing” a machine or some thing like that . Also, I keep seeing refrances to docker requiring a windows 10 PRO or enterprise OS , but I have win 10 home on my machine.
having said that…
I open webODM - intialisation failed
console - Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Initializing console…
OpenSSH check passed
Error checking TLS connection: machine does not exist
webodm - virtualbox Error Unknown machine does not exist
WebODM VM exists, attempting to launch it…
Starting “webodm”…
Could not start virtual machine. Check the console for error messages and attempt to fix the problems manually, then restart this application.
if I then try to open docker, I get a few lines of stuff, and “waiting for an ip…”
The error seems to be that Starting “webodm”… machine does not exist for some reason the VM has been deleted. Try to press the “Remove VM” button from the “maintenance” panel, then restart WebODM Manager.
