Webodm account keeps saying I don't have enough tokens to process
IMPORTANT! Having issues processing images?
I have the one time fee of 57.00 dollars for my webodm account however every time I go to process images it keeps saying this! webodm|690x388 “Not enough credits we estimate you need 27 credits to process this data set.” I was able to process before fine without any issues, now this is popping up. I’m using the normal Webodm interface not the lighting. Any help will be greatly apprieciated.Thank you!
Hey @AVTDRONES, check that you are using your local processing node for processing. Do not select “Auto” (which is probably sending the task to lightning), select “node-odm-1”.
Thank you very much for the quick response, I’ll try that now. Thank you again.
