Hi, I have the same dataset of 202 pictures os facade of a church, on 2 different server with 2 different version of WebODM, the first installed in 2021 and the second installed on other in 2022.
If I see camera position, I see the 10 cameras are not corretcly positioned respect the facade. It 's probably a fault of GPS signal. But I’m using a simple Mavic Mini that uses the GPS of my Smartphone.
In he old version the facade is reconstructed properly, and seems that doesn’t be affected by the GPS error.
In the WebODM 1.9.14 the GPS position is respected and I obtain an error as a result.
Is it possibile to disable GPS position during the reconstruction?
So, we can say that, old version was robuster than recent in feature detection with low number of features.
In recent version we need to increase th min-num-features: (20000 insted 10000) .
“orthophoto-cutline: true” is this parameter essential?
I’ll try your settings on my server. I’ll be back soon with my results.
Hello, just a few small historical notes. This is a pieve, a medieval church used to manage the territory and dispense the rite of Christian baptism. It was built, according to archaeologists, in the 5th-6th century AD, during the time of the Ostrogoths in Italy and it reused materials from a Roman temple in its foundations. In fact, the lower part of the facade is made up of blocks that probably come from the cella of the Roman temple.
