Web ODM raster download EPSG conversions
When you request a customer EPSG Raster Download, Does WebODM make the necessary datum conversions say between variations of WGS to NAVD88?
Thanks in advance.
Do you have a particular example of what CRS you are concerned about?
Yes, UTM 15N (32615) to Texas North Central State Plane (6584) When the conversion is done properly ( geodesic transform ), the whole image should move ENE about 1.5 Meters. Thanks in advance. If you use GDALWARP, you need to employ the 7 factor Helmert transform. Thanks in advance.
Are you able to provide us data to test and confirm with?
Have you confirmed an issue with this transform?
This image set happens to be a park in El Paso TX, but it shows the same problem. The image file shows the EPSG. They lay on top of each other in QGIS. The error is 1.4 m ESE from an RTK measured Check Point. Forgive my earlier comment, the position correction should be WNW between the NAVD88 and WGS datum position. I have verfied this error at numerous locations across the US and it is consistent.
ODM conversion examples.
Thanks in advance for your help.
Konrad
Saijin. Were you able to replicate my concern
No, not at present.
Are you able to open this as an issue on our GitHub tracker with any examples and supporting information you have?
I’ll be happy to do this. I think I know the answer and it involves to an explicit transform using the -ct command in gdalwarp.
Konrad
