Web Dronemap camera calibration
I’m having problems with the processing of orthoimages generated by a Samsung camera and a fixed wing with pixhawk controller.
I believe it is because of the distortion of the images because I can only process some images of the flight.
Could anyone tell me how to proceed in such cases?
here are some images that can not perform the alignment.
Using other softwares like agisoft I usually get
Thank you for help.
Try preprocessing through lensfun.
See this thread here: Problem with webodm generated DSM/DTM - #18 by Peke
Can you help me?
I did the processing in the darktable only that WebODM can not advance of step resize images
Can you explain the problem in more detail?
