Web Dronemap camera calibration
I’m having problems with the processing of orthoimages generated by a Samsung camera and a fixed wing with pixhawk controller.
I believe it is because of the distortion of the images because I can only process some images of the flight.
Could anyone tell me how to proceed in such cases?
here are some images that can not perform the alignment.
https://1drv.ms/f/s!AjlW63Tp9gQvjSdmnolj0FUY61LL
Using other softwares like agisoft I usually get
Thank you for help.
Try preprocessing through lensfun.
See this thread here: Problem with webodm generated DSM/DTM
Can you help me?
I did the processing in the darktable only that WebODM can not advance of step resize images
Can you explain the problem in more detail?
