[WARNING] GCP line ignored (image not found): RuntimeError: A GCP file was provided, but no valid GCP entries could be used
WebODM using Docker with WSL2
[WARNING] GCP line ignored (image not found): RuntimeError: A GCP file was provided, but no valid GCP entries could be used.
Your help would be much appreciated since I’ve tried everything, even re-installed Windows 10.
When running a project without any GCP file, everything works.
The moment any option of processing (Default) and other setting, is used
the process halts shortly after the images are uploaded.
The log file shows that the GSP line was ignored … for every line of the GCP file, produced by
the GCP Editor Pro,
and in the following processing it says a GCP file was provided, but valid entries could be used.
Error Message
Is my install faulty in any way, I use the WSL2 procedure ??
How can I fix this so that my models are referenced?
Your help is much appreciated !!!
Hmm, this is an interesting one.
Can you please provide your GCP file and images on a sharing platform (dronedb.app, OneDrive, Google Drive, Dropbox, Box.NET, etc.)?
